Question about Whirlwind FH-778 Air Conditioner
Hot Air from the Cooler Hi, my cooler is blowing hot air (its like a fan) instead of cool air.please help. it was perfectly working till yesterday. thanks
    Problem Solver:
  • 6 Answers
Check the a/c unit. make sure you dont have any leaks around your system. sometimes when you have a small leak it will take time to lose out of system. but you may need to charge your unit up again. Also your compressor may be out of service. check and make sure compressor is running
Posted on Apr 01, 2009
In AC mode the cooler fan doesn't turn on and after a little while the warm air starts to blow instead of cold air. Any ideas
Sounds like a bad or stuck reversing valve. Typically r.vs. are energized in cooling, verify 24 volts to valve, if yes , bad valve
Sep 30, 2016 | Whynter ARC-14SH ECO-FRIENDLY 14000 BTU...
Honeywell 97-4118/5-89
probably low on freon. i assume compressor is running?
Jan 25, 2014 | Honeywell ER150B Air Conditioner
Compaq cq-45 laptop light near to caps and scroll blinks , No display
In Most cases this happens when using Nvidia graphics.
You need to open your laptop - call a technician for professional Job is you are not able to do so.
After removing the cooler which usually comes with a small fan (covers the main processor), remove the processor and you will see a chip that need a "HOT AIR STATION" this tool blows very high temperature of air on the surface.
well I used my wifes Hand Hair Dryer - also does the magic.
see image on where to blow the hot air.
now after blowing the hot air, mount your laptop again.
but first, let it cool down.
Sep 04, 2013 | Compaq Presario CQ-45 Laptop Universal AC...
Why is my laptop overheating?
You can try a Targus Lap cooler to circulate the air a little better. The fan may be working but just not as efficiently as it used to. You probably have noticed that it works longer and better in cooler rooms as well. A lap cooler will help with the cooling issue.
Jul 22, 2010 | Dell Inspiron B130 Notebook
Phillips Freevents 11NB5800
Hello sir, hi, try to check if the side exhaust fan is blowing out reasonable amount of hot air, if not you side exhaust fan is dirty, it may need cleaning, If the exhaust fan has reasonable amount of hot air blowing out, then you may need to buy laptop cooler, inquire about it at your laptop dealer.
Nov 07, 2009 | Computers & Internet
HOT AIR BLOWING INSIDE THE HOUSE
I know there are not that many sites--very few--that cover the informational guidance on the maintenance and technical difficulties of evaporative coolers, and so I feel compelled to share with you this very good, but rare, handyman site that does:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Coolers.htm
As you'll see, the link above has a section dedicated to evaporative coolers.
As to your specific problem of your cooler's blowing hot air, yes, the humidity is listed as one of six (6) possible causes of this cooler problem. To find out whether the other five causes are applicable to your situation, here is the direct link to the diagnostic article on hot-blowing coolers:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Coolers_Cooler_Does_Not_Blow_Cool_Air.htm
You should be able to review this article, and, one by one, determine what causes listed therein are not affecting your cooler in order to ultimately end up with one remaining listed cause that is the likeliest cause of your cooler's failure to blow cool air into your house.
This should help.
Brad
Jul 08, 2009 | Mastercool 67680 Evaporative Cooler Air...
Water Cooler Not cool
hi,
Please check the control.
May 06, 2009 | Heating & Cooling
Commercial cooler
hi thanks for the question its good that its blowing hot air only if its on the outside . let it run for 24 then check it if it was the dirt it will start working again give it some time the appliance doc
Sep 27, 2008 | Frigidaire FRS23KF7AB Side by Side...
My Dimplex DAC12AC aircooler is blowing out hot air
Hi,its possible have a problem your PCB Board ,the 17c is so cool setting but blows hot , and the E3 simble its min High Cooling , pls check ur PCB board to the nearest service center.
Jan 07, 2008 | Heating & Cooling
Heating & Cooling Logo
154 people viewed this question
Top Whirlwind Heating & Cooling Experts
Dennis Boxerman
Bill Long
Dan Webster
Dan Webster
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
