Question about Sharp AR-C160 Color Copier
Sharp Printer/Copier AR-C160
What is error code L4-04? How do I fix it?
  • bakalarr Apr 20, 2009
    Even when I try:
    P
    Interrupt
    C
    Interrupt
    14
    Start
    Execute
    The machine still will not clear the error, nor does it restart? Are there any more solutions? Am I doing something wrong?
    Thank you!!
    Scholar:
  • 60 Answers
This answer is a rip off of MEITECH's answer to a very similar machine with the same code. I worked on Sharps for a few years and what he sais about this makes sense.
Here's the link:
http://www.fixya.com/support/t1640062-sharp_arc_270_error_code_l4_04
I give him credit and I gave him a 3 square rating for the help. He and I could both use a little rating boost. Thanks.
Possible bind in one or more of the developer units. Replace as needed.Sec. 11 Page 11-61 it talks about Paper Feed Drive Motor, it is thesame motor as the Black Developer Drive Motor.
For L4-04 swap those two motors around to troubleshoot bad motor
Posted on Feb 21, 2009
We have a sharp AR C-260 and we have a H5-01 error however i cannot put in the # * c * code any ideas?
H5-01. 5 Continuous POUT not-reached error
perform the following procedure to enter the simulation mode.
#-interrupt-c-interrupt-14-ready key
Apr 07, 2011 | Sharp AR-C160 Color Copier
Error code L4-05 for Sharp AR-C160 Digital
main motor lock detection
shifter motor trouble
Nov 26, 2009 | Sharp AR-C160 Color Copier
F2-57 Sharp AR C160 color copier
This is a problem with the drum and you may need to replace it to fix this problem...
Feb 16, 2009 | Sharp AR-C160 Color Copier
F2 ERROR CODE
WHEN F2 FLASHES JUST PRESS START KEY U WILL RECEIVE A SUB CODE.IF SUB CODE IS 02 THIS IS TONER SUPPLY PROBLEM IF 04 THIS IS DATA PROBLEM LIKE AS IDENTIFICATION PROBLEM MODEL ERROR TYPE ERROR.BYMIAN AKHLAQ
Oct 22, 2008 | Sharp AR-C160 Color Copier
Sharp AR C160 - Error H4-00
The thermistor inside of the fuser needs to be reset before you can clear the code. If you remove the top cover of the fuser the thermistor is located on top of the upper fusser roller. It should be reset able by pushing in. Then you put in the reset code. you may want a tech to look into what caused this.
Hope that helps...
Lbcoaster
Sep 16, 2008 | Sharp AR-C160 Color Copier
Error code H4-01
This mean you have low temp. on heat lamp 2 program interput clear interrupt 14 print may clear this code. if not you can look at the fusing unit and reset thrmo breaker that may be pop off.
Jul 26, 2008 | Sharp AR-C160 Color Copier
F2 usually means its a component failure that should be looked at by a technician. You could trying turning it off wait 30 seconds and turn it back on again to see if it goes away.
Jul 23, 2008 | Sharp AR-C160 Color Copier
Error code F2-45
Ihave Sharp AR-C160. WHAT DOES THIS H4-01 ERRO CODE MEAN? How do I clear it?
Jul 18, 2008 | Sharp AR-C160 Color Copier
Error Code
go to service mode then cancel it after that switch it off for 5 seconds then turn the machine on again
Dec 27, 2007 | Sharp AR-C160 Color Copier
Ar-c160
Make sure there is no paper jammed in machine, H5-01 means 5 jams same location. Use quality paper not recycled and make sure it is fresh not old stock
PROGRAM INTERUPT CLEAR INTERRUPT must be SUPER FAST then 14....WILL RESET CODE
Dec 16, 2007 | Sharp AR-C160 Color Copier
Sharp AR-C160 Color Copier Logo
162 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
