Question about Kenmore 24032\24036 Top Load Washer
Washer leaks and tub won't empty in the beginning of the cycle
Kenmore 80 series mod. 110
  • 3 Answers
Check your hoses all the connections. you'll have to pull the part with the knobs off to do this inside. If it isn't turning, but the motor runs, it might be the coupler in the bottom of the washer connecting the motor and transmission.
Posted on Feb 23, 2009
Kenmore 80 series washer model 110 doesn't fully drain when cycle complete
With the lid open, try to turn tub by hand. If you can you may have a bad clutch. If you hear the washer agitating at the begining of the cycle without any water and filling at the end of the cycle, replace the ATC switch. Try spin cycle and open the lid, if you don't see the tub turning, but hear the motor, check motor coupler, or if it never spins after you close lid, check lid switch. These are the most common solutions to this complaint.
Sep 02, 2014 | Washing Machines
I have a Kenmore series 80 Model 110 washer that drips inot the tub after the cycle. It's not a problem if I get the clothes out immediately. The leak seems to be getting worse. Any ideas on a solution?
Replace the water inlet valve on the back where the water hoses connect to the washer. It isn't sealing good. You may have to remove the top to access it.
Aug 16, 2010 | Kenmore Washing Machines
How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 80 series mod 110225842400 stopped working during cycle. Tub won't drain and will not agitate.
Hi, When the washer is in spin or wash cyles, do you here any motor noises? It sounds like the lid switch might be bad. Sometimes you can actually see if the lid switch is broke or not. Please let me know if The lid switch appears to be the problem or if I can assist you further.
Vic
Jun 20, 2009 | Kenmore 20172 Top Load Washer
Water will not shut off to begin cycle
Does the washer leak water into the tub even when it is not on. If so, your fill valve is leaking or sticking.
I would also check the following components for problems:
-Air pressure switch. This is usually located inside the control area and likely is attached to the water level control. Try attaching a small piece of tubing to the pressure switch and gently blow into it. If it turns off, the problem likely lies elsewhere.
-Air tube. This clear tube can get crimped or worn from the vibration of the washer's normal operation. Any holes, cracks or crimps will prevent the air pressure created by the water in the tub from getting to the pressure switch.
-Soap residue in the air dome. The airdome is the piece attached to the side of the washtub that allows water in the tub to exert air pressure into the tube and the pressure switch. Soap residue can create an obstruction that prevents the pressure from being transmitted up the tube. Try cleaning with vinegar or ammonia. (Remember: Clean the tub and tubing thoroughly with water after cleaning. Ammonia and Vinegar are both corrosive to electrical parts.)
Hope this helps!
May 28, 2009 | Kenmore 23822 Top Load Washer
Kenmore 80 Series washer will not spin; MOD#110-22882101
you need to replace the motor coupler between the motor and the trans.,let me know if you need more help,mike
May 26, 2009 | Washing Machines
GOES TO SPIN CYCLE THEN STOPS SUDDENLY AND REFILLS WATER IN TUB
Are you sure you don't have a second rinse button that is selected.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
70 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
