Question about Car Audio & Video
Rockford Fosgate P250.2 - No Power
I have found a Rockford Fosgate P250.2 2 Ch. Amplifier (250W) that is being sold for next to nothing but it is being sold as-is since it does not power on.
Here are my questions:
1. Is there a typical cause to this type of problem with this product?
2. Would it likely be fairly inexpensive to perform the repair?
3. Could a working version of this product power 2x 12" 4 ohm subs and sound pretty good? Or would 1 x 12" 4 ohm sub sound better?
Any information is appreciated.
Thanks
  • Perry Babin May 11, 2010
    If there is no power and the fuse isn't blown, it's likely that the power supply FETs are blown. The parts are likely to cost less than $15 if that's all that's wrong with it. They are soldered to the MEHSA insulator and you'll need a small butane torch to remove and replace them. You should also be able to buy the insulator/transistors assembly from Rockford but I don't know what it will cost from them.
    Sometimes, there are other problems that cause the power supply FETs to fail. If the output transistors failed, they could have caused the FETs to fail.
    With either of these faults, there may be additional damage which may or may not be difficult to troubleshoot.
    It's also possible that the board is badly damaged (sometimes happens when the power supply FETs fail). This can make it difficult/impractical to repair.
    If you buy it and need help with it, let me know if you need help repairing it.
    babin_perry@yahoo.com
  • 80 Answers
1. no all amps can go bad with a bad installer !
2. repairs sometimes go for as much as it was new! so somettimes not worth it!
3.1 12 4ohm would sound lot better i reccomed mono amps for subs being they only put out low feqz and are better and more battery effient!
Posted on Feb 27, 2009
Protect light stays on and nothing else
Your amp is fryed it happened to me. Pull the covers off so you can see the mother board and Then try connect all wires. But don't connect the light up display. Good luck. Im gets a bit Hot now and only two ch work
Nov 05, 2011 | Rockford Fosgate Punch P4004 Car Audio...
Where is the power input cable on my x6 rockford fosgate amp
RF uses some pretty funky cases in order to hide the wiring.
usually a screw or 2 on the top will allow its removal and expose the wiring terminals
May 08, 2011 | Rockford Fosgate X6 Type RF 1-Channel...
Do you know where I can fix my Rockford Fosgate Power 1000BD Car Audio Amplifier inside tucson? what could be the best choice? fix it ? or sellin it?
You could open it up and if you are familiar with soldering that is most likely your problem something that was soldered down has come loose.
Mar 03, 2011 | Rockford Fosgate Power 1000BD Car Audio...
I need a schematic for a RF p300-1 amp. Im trying to replace 2 of the mosfet semiconductors that got fried.
There are no schematics for RF amps, normally RF uses standard IRF Mosfets. Can you decribe the area where they blew, Power Supply are usually N-Channel high current type. Outputs can be either N-Ch or P-Ch depending on the Power rail there attached to.
Dec 23, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Rockford fosgate p5002 amp keeps blowing fuses as soon as i turn it on.
make sure your power hasnt found its way in the the ground and vice versa
Apr 02, 2010 | Rockford Fosgate Punch P5002 Car Audio...
Hi..i would like to buy the Rockford Fosgate T10001bd parts .modle no' TO-247 75344G.Where can i buy please
Hi there are numerous places to buy parts for Rockford Fosgate amps. You can go directly to the support section at rockfordfosgate.com or there main repair center is landis tech in North Carolina. Or you can try Freemans car sterio Charlotte, NC
6500 E. Independence Blvd.
Charlotte, NC 28212
704.531.0550 ask for Jay in parts service. Thank you for using Fixya.com
Feb 07, 2010 | Rockford Fosgate T10001BD- Car Audio...
What is the auctual watts fpr the Rockford Fosgate Punch 401S?
rockford fosgate doesnt have watts its considered monoblock it gives off watever the speakers want....it gives them the power they need
Dec 29, 2009 | Rockford Fosgate Punch 401S Car Audio...
Rockford Fosgate punch protection light
power it off, then on...check you're fuses. unplug the car battery and try again. good luck.
Sep 05, 2009 | Rockford Fosgate Punch 800a2 Car Audio...
Rockford fosgate amp 5 ch
most likely your remote wire or remote crapped out if not its your amp itself can you adjust and play without remote? if so go to this site for info and replacement as well as tips:
http://www.rockfordfosgate.com/rftech/wire_calculator.asp
Dec 05, 2008 | Rockford Fosgate 800.2 Car Audio Amplifier
Not working
maybe you should use 4 awg wire
Jun 24, 2008 | Rockford Fosgate Punch P5002 Car Audio...
Car Audio & Video Logo
184 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
