Question about Westinghouse LCM-22w2 Television
White screen - Westinghouse LCM-22w2 Television
  • Chuckus Feb 24, 2009
    I have the same problem, at first I was able to get it to work by unplugging and replugging it in, now it keeps getting worse. I belive the logic board associated with the backlight is malfunctioning. Causing the backlight to stay on regardless of the input signal. Any suggestions on repair?
  • Anonymous Apr 03, 2009
    same thing for me. when i power off, it just stays white. also when changing inputs, it flickers white.
  • 13 Answers
I fixed it! It's the power supply board.
The Westinghouse LCM 22w2 has bad capacitors on the yellow power supply board. This is a common problem plaguing motherboards and LCD flatpanels that use capacitors from Taiwan. If you know how to solder, or know somebody that can, it's actually a pretty easy fix. Take out the yellow circuit board on the inside, write down the specifications for each of the capacitors (the cylindrical things) go to the electronics supply store and get the replacement capacitors. You can go over the voltage specification (not under), but keep the capacitance value matching. Replace one at a time. Go to for advice, tutorials and training on doing this. *You really should replace all the capacitors*, but the very large one next to the power plug I did leave on the board because I couldn't find a match. To my delight, the white screen of death went away and it was working as new!
I saved a ton of money fixing this, it's definitely worth learning how to solder to do this. for professional hosting solutions
Posted on Apr 09, 2009
White screen
"White screen" on Samsung LED TV - Forums - CNET > Forums > Samsung
CNETJun 11, 2015 - I guess I better send it to the repair shop and prepare myself for a long break ... Hello i have experienced the white screen tv as well, i got mine as part of a deal ... Samsung LCD Green Screen
Jun 11, 2015
Samsung DLP TV w/ White Dots on Screen
Jun 11, 2015
Samsung DLP white dots fix?
Apr 10, 2012
Samsung LCD TV now bright white screen
Aug 1, 2011
More results from
? 4:42
May 11, 2013 - Uploaded by Tampatec
EASY Common LCD REPAIR Blank WHITE DISTORTED VIDEO... LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test ...
Samsung TV "white screen" repair - YouTube
Dec 16, 2015 | Televison & Video
How to fix an intermittent white screen on a Samsung television?
Ask them to replace the t-con board. It could be a defect one.Good Luck.
Oct 01, 2015 | Samsung LNT3242H Television
White Screen I have a white screen and can't get rid of it. I tried taking the batterie out and it still had a white screen and I shut it off and on a lot but still a white screen. What do I do?
check the screen display unit would have been damaged if so
you will be compepelled to replace it do not do it yourself take it to a
reliable repairer
Jun 15, 2013 | Nokia 5320 XpressMusic Cellular Phone
My N72 is not showing any display... just a simple white colour screen
Did your phone drop on the flow? Is it just showing white and still works ?or Display white screen and not working?
For a phone to display a white, does questions need to be answered..
If it fell on the flow it's usually a screen fault and it needs to be replaced.
If it didn't fall down, but displays white screen and nothing function,it a software faulty needs a memory restoring..
If just showing white screen and you still can make calls with it, then it's screen fault needs to replace..
Feb 11, 2010 | Nokia N70 Cellular Phone
White Screen
ma k800i has a white screen and i thik its a software problem
Jun 24, 2009 | Sony Ericsson K800i Cellular Phone
Sony screen is white.
is there screen fully white or white screen with some horizontal lines ? pls send ur feed back
Dec 10, 2008 | Sony Grand WEGA KF-50WE620 Television
Nokia K750i
If the new screen is white and old screen displays 20% of the display then you can check by flashing the software , in most the cases white screen is the software problem.....
Aug 17, 2008 | LG M4410 Cellular Phone
White screen on nano ipod
I have had this problem recently myself and would like you to know that it is possible to fix. The white screen error or otherwise known as "white screen of death" is caused by the lcd color screen on the ipod itself. That is why its functions still work but the screen does not. Once you replace the color screen it will be as good as new.
Aug 11, 2008 | Apple iPod nano
White screen
how do you flash the firmware using pc. can u tell the procedure
Apr 27, 2008 | Nokia 9300 Smartphone
White screen on lcd and regular screen
i repaired one not to long ago te flex cable going to the screen from inside the camcoder was cracked
Aug 20, 2007 | Samsung SC-D23 Mini DV Digital Camcorder
Westinghouse LCM-22w2 Television Logo
730 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
