Question about Philips HTS3410D/37 700W DVD Home Theater System System
My samsung dvd/vcr v5600 will not power up.
Power is on at outlet, no indicators at unit
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Almost always, your described problem indicates a blown fuse inside the DVD/VCR combo. Exact location would depend on the model and regional version. What is common to all is that it would be immediately after the power cord as it enters the combo unit.
Some ideas to further guide you if the fuse is glass tube type:
  • if the break of the fusible wire is clean, then it would be relatively safe to simply replace;
  • if however, the glass tube is darkened with burnt marks, then there would be some other components defective such as the regulator transistor and/or filter capacitor.
Good luck and thank you for using FixYa.
Posted on Feb 21, 2009
Does samsung v5600 copy vcr to dvd internally
Does not appear from the owners manual that this unit can do that. Very few units have that ability.
Jul 07, 2016 | Samsung DVD-V5600U DVD Player/VCR
Samsung SV-DVD545 dvd / vcr combi unit cuts off after switch on
i would guess your vcr is not powered off completely preventing the dvd from playing
May 15, 2012 | Televison & Video
I need an instruction book for Samsung DVD/Video Player V5600
Hey!
You can get it freely from here!
Jest enter the digits of he verification image (below) and click Download Now.
Regards,
Pelu.
May 10, 2010 | Samsung DVD-V5500 DVD Player/VCR
Can I record programmes from tv whwn I have samsung dvd v5600
Afraid not! ... You need a Recordable DVD player to record TV programs....
The Samsung v4600 is just a DVD player, with no recording capabilities.
Sep 24, 2009 | Televison & Video
My DVD/VCR player does not receive power what is wrong and can I get it fixed? The power cord has not cuts, I have tried multiple outlets and still nothing
have you checked to see the prongs/ground aren't loose or broken off?
The cord might be bad, or the power converter inside could be bad. do any lights come on at all?
Aug 09, 2009 | Samsung DVD-V4600 DVD Player/VCR
DVD VCR combo has no power
I found out what the issue was with my Samsung DVD-V5500. It was the rectifier diode on the 15V tap of the high frequency transformer. This is the same issue that someone else with a later model V5600 had talked about. The diode had shorted and behaved like a piece of wire.
Seems to be a bit of weak point in the power supply. The issue can be diagnosed by using a multimeter to measure the resistance between the diode cathode and ground. If the meter is measuring 1 Ohm between the cathode and ground, your diode needs replacing. I just replaced it with a UF4003 diode from Jaycar, which is basically an Ultra Fast 200V 1A diode suitable for switching the high frequency (20-30kHz) output from the transformer.
The diode is located at the rear right hand corner of the board on the output of the power supply section. A picture below shows the new diode between orientated east-west between the large capacitors. The original diode that failed was an SHG2D SHS.
Sep 04, 2008 | Samsung DVD-V5500 DVD Player/VCR
Samsung v5600
be sure that have a power in your outlet. if fuse is good try to check the diodes on the power supply, some diodes may be open.
Jul 01, 2008 | Samsung DVD-V4600 DVD Player/VCR
Multi Zone code Samsung 5600 DVD VCR Combo
Try this site:
http://www.videohelp.com/dvdhacks/samsung-dvd-v5600/7031#26074
Particularly the entries from:
Region code hack posted by Anthony Green, September 10 2006:
And
Region code hack posted by ZoidsGodzilla, November 22 2006:
Good luck
Jan 01, 2008 | Samsung DVD-V4600 DVD Player/VCR
Doesn't power ON
If you have no indication of power at all,(no lights,no display)the fuse is the first component to check but the vcr has be unplug from the wall when you remove the top cover and remove the fuse to check it.Be carefu.
Sep 25, 2006 | Samsung SV5000W VHS VCR
123 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
