Question about Pioneer Audio Players & Recorders
Pioneer plz93 turntable, Auto return arm will not return?
I have a pioneer plz93 turntable, Once the reord finishes the needle arm will not return to the the arm rest? it just stays at the end of the last track?
5 Suggested Answers
djproaudio
  • 515 Answers
SOURCE: Kenwood KD 3070 turntable
There should be a set screw that you can tighten in order to adjust the height return. If you do not have anything like this, perhaps your record is raised too much. How thick is your rubber mat? Do you have any other mats sitting on top of this?
- OPTiC
DJ Pro Audio
www.1200s.com
www.repairnyc.com
Posted on Sep 13, 2008
SOURCE: drive belt rubber
www.NeedleDoctor.com should have your belt.
Posted on Nov 21, 2008
lesliemurphy
  • 69 Answers
SOURCE: Needs a needle
try this company?
mailto:info@needledoctor.com
Posted on Oct 07, 2009
digger odell
  • 8 Answers
SOURCE: I have an PLZ460 Pioneer turntable. Played it for
Yes there should be an adjustment at the base of the arm to use a scewdriver to move the are back and forth.
Posted on Jul 30, 2010
SOURCE: the arm will automatically return without playing the record
RE:
With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default
This actually worked when I spun the record in reverse 6 times. By the 6 revolution the arm is already touching the record and the motor in motion: from there I let it go and it plays...and now is in manual mode. Meaning I am able to lift the tone arm and advance to where I'd like.
Posted on Feb 18, 2013
I've recently picked up a Pioneer Plx-88z turntable second hand. I know that the player is working ok as putting the arm on the record plays music. The problem is that after a few seconds, no matter what,...
Hi, if it's a second hand device. there must be something wrong with the arm at it's moving axe. if something (dust or broken support) is blocking it, it will return automatically to its rest position to avoid any damage to the fragile and sensible "head"
Jun 02, 2014 | Audio Players & Recorders
Changing the needle-how to!
Replace the Needle with a new one (part No. PZP1004) . Remove the old Stylus (or Needle) by pulling it downwards gently, and push the new Stylus/needle in place as shown in the below photo.
061fed0.jpg hope this works for you,
Cheers
Emmanuel
Sep 13, 2008 | Pioneer PL-990 Turntable
The arm will automatically return without playing the record
Hi Lisa, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Nov 28, 2011 | Audio Players & Recorders
I have a Pioneer PL-740 turntable that works extremely well, except there is zero damping when either lifting or dropping (and I mean dropping) the needle. I know there is generally a hydraulic oil that...
most turntables actually only dampen during automatic play and return (eject) not when manually manipulating the needle. Better turntables will have a counterweight at the back of the arm behind the pivot point, but that is to decrease wear on the vinyl and increase needle life and audio fidelity in the higher end.
Some turntables have a lifter arm that is dampened, but if your player doesn't have such a mechanism, or if it has one and you choose to manually manipulate the needle without it's usage, there is no dampening.
The fix unfortunately is to buy a turntable with a dampened lifter arm, and to use the arm when lifting and lowering the needle.
Mar 23, 2011 | Pioneer Audio Players & Recorders
TONEARM DOES NOT RETURN AT FINISH OF RECORD MODEL PS-X7
http://www.youtube.com/watch?v=PS6g9rQRF9M The Levitator is a tone arm "auto lifter" for turn tables and record players that do not have an "auto-return" feature, or has one that is broken. If your needle rides in the "wax trail-off" area of a record it can damage the needle, along with making a horrible noise. It is not enjoyable to have to babysit your records and manually take your tone arm off the record the moment it is done. The Levitator does it for you so you can relax and go about your business. When the record is done the tone arm trips the lever triggering the lifter to raise your tone arm/needle off the record. It is designed with adjustable height to fit any turntable. These are available for sale through Ebay,or please see video to order your own.
Jan 31, 2011 | Sony Audio Players & Recorders
Where can I buy Pioneer turntable belts in Pietermaritzburg, South Africa?
My Auto Return Stereo Turntable , PL - 640, Quatz - Direct Drive is not playing, could you give me contact no around Pretoria or Midrand or even Johannesburg where i can send it for repairs
Apr 07, 2008 | Pioneer CDJ-800MK2 Turntable
634 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
