Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Dog chewed sensor wire so garage door won't, i
Dog chewed sensor wire so garage door won't open, i need to know what type wire i can use to fix or make the connection back or do i have run more wire, an help or advice would be very much appreciated.
Nicole J.
  • 360 Answers
Basically any bell wire will work, available at any home centers everywhere. if the existing wire is long enough, just wire nut it together (white to white, color to color)
Posted on Feb 21, 2009
Garage door sensor blinks continuously - door wont close
It is getting a signal, but the wrong code. Call the dealer for your garage door and ask for a solution.
Jul 28, 2013 | Sears Craftsman LiftMaster Chamberlain...
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have a liftmaster formula 1 garage opener. My dog ripped out the line out of the wall that connects to one of the sensor. I do now know where the line runs to inside the wall. Looking for a wiring...
Hello. The line from each sensor runs to the control panel on the motor. If you climb up and take a look at the rear of the motor you will see the other end of each wire. J.
May 27, 2010 | liftmaster Chamberlain Garage Door Opener...
I have just replaced 2 sets of safty sensors on my craftman door openers. They where damaged by a chewing puppy. The problem is that the sensor lights will not come on. Ohm readings at the opener with the...
There is no reset for the sensors. Make sure you have them wired correctly. The solid white wire from each sensor go to terminal 2 and the wires with the black stripe go to terminal 3. Also make sure the sensors are pointed at one another.
Nov 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
I DONT REMMEMBER HOW TO SET UP MY GARAGE DOOR OPENERS SENSORS ?
You have to match the codes of the garage door you're trying to open.
Aug 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
1/2 HP Sears Liftmaster will not close
YOU PROBABLY HAVE A BROKEN WIRE ON THE SENDING EYE. THIS WOULD CAUSE IT NOT TO LIGHT AND THE RECIEVER NOT TO GET A SIGNAL MAKING IT NOT LIGHT.
YOUR DOG IS PROBABLY THE CULPRIT AGAIN . THEY TEND TO SNIFF AROUND OR JUST GENERALLY BUMP INTO THE WIRES (SOMETIMES THEY CHEW THEM).
IF NO OBVIOUS BROKEN WIRES OR LOOSE CONNECTIONS CAN BE FOUND. YOU CAN TEST THE WIRING BY USING DOOR BELL WIRE TO TEMPORARILY REPLACE IT - THE FAULT COULD BE INSIDE THE WALL OR UNDER A STAPLE WHERE THE WIRES GET SMASHED (THIS ONE WE CAN'T BLAME ON THE DOG) :)
IF YOU REWIRE COMPLETELY (PAY ATTENTION TO THE POLARITY OR THE TEST WILL NOT BE VALID) AND THE LEDS STILL ARE NOT ON YOU COULD HAVE A DEFECTIVE EYE
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to know wiring scheme on back of garage door opener
join both wires the white one with the white one, and the white with black strip, with the same other, then connect it on the back of the motor the white wires with the white terminal (a white square) and the white with the black strip with the black terminal (a black square) .. check that both leds of sensors are on
Mar 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
One sensor light is blinking green, the other sensor light is bli
the safety eyes are wired wrong on the back of the opener. Check the wire locations.
Nov 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Wiring diagram for garage door opener
Can you hook up sensors to an older craftsman garage door that never had them?
Jun 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Wiring the opener and sensors
The wall button gets the red and white wire. The safety eyes use the black and white wires. There are two types of attachments on the back of the openers. One has three screws. On this type the 1 is for the red wire, the 2 is for all white wires, and the 3 is for all black wires. The other type has four blocks and you just match the color to the wire color.
Jan 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
139 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
