Good evening to all. I have upgraded the RAM on my Mobilon HC-4600 by passing it from 16 to 32Mb and since the touch-screen doesn't work well. First at startup, only 3 inches on the left handside of the screen responded to touches during Recalibration. It seemed the right hand side of the screen was disconnected. After recalibration, only the same portion responds but not well, like if one uses the Shift screen while clicking on a mouse: everything selects while you move the stylus around. I loaded the patch for memory and stylus sensitivity but nothing much better, except the recalibration is possible again, but when confirming the settings the screen still responds crazy. I also tried to reput the original 16Mb RAM but I have the same problem. What can I do? Why does the screen work well only during recalibration? What settings could I change in regedit or by loading software. Thanking you in advance Louis
-   olha só eu comprei um mobilion e não funciona nada na no touch...... e o pior e que comprei de 2ª mão e não tenho os drives....como fazer?
-   Guest
Solution #1
posted on Aug 01, 2007
kcw573 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
I tried sensitivity.exe but nothing better. Only re-calibration is better. After, screen goes crazy. What patch were you suggesting?
Was this helpful?
Yes
No
Solution #2
lawyer - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Was this helpful?
Yes
No
Solution #3
Jimmy NY - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
if the patch at # will help
Jim
Was this helpful?
Yes
No
Solution #4
pawa - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Yes, I double checked the 32Mb Ram connection by taking it out and re-pluging it in again. I also re-put the original 16Mb RAM and had the same problem. Unless there is a connection with the screen somewhere I touched without noticing but it doesn't seem so.
Was this helpful?
Yes
No
Solution #5
LiZzIe - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Go to the Sharp Mobilon discussion forum at #
Several Mobilon users have experienced touch screen problems and can respond to your issue there.
Unfortunately, you may be outta luck unless your Mobi is still under warranty.
Was this helpful?
Yes
No
Solution #6
Odud - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Have you tried a 'soft' reset after recalibrating? Also you may want to make sure the ram module is really securely seated.
Hi there! I have the same problem with my Mobilon HC4600. The screen doesn't respond at all!...
(More)
Hi there! I have the same problem with my Mobilon HC4600. The screen doesn't respond at all! & because of this, i cann't use a lot of the menu options(the touch screen ones, anyways!) If there's something that anyone can do to fix this problem, i would greatly apperciate it!! Thank-x, MzDetailing.
when i connect my hc 4600 to my pc via serial cable( one that looks like an opposite of the monitor...
(More)
when i connect my hc 4600 to my pc via serial cable( one that looks like an opposite of the monitor cable), it tells me an error has occured. it sais... connecting device>>>device connected>>> authenticating connection... and then it stops?
(More)
I can not use all functions in my Sharp HC 4600 handheld PC since the touch screen stoped working ....
(More)
I can not use all functions in my Sharp HC 4600 handheld PC since the touch screen stoped working . What should I do ?
I really don't know what happened because my Sharp Pc was used properly and one day suddenly it stop responding . Is it a software problem or there is something else I didn't suspect .
Wainting your quick reply
Best regards from Mirek - Poland
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
