SOURCE: there is no video on my kenwood ddx8017, why? Do i
If you want to watch videos on your unit it is necessary to bypass the parking brake wire from the Kenwood unit. The parking brake wire is light green and the best possible way to bypass the unit is by installing a toggle switch. The toggle switch should be a two wire device. Connect one wire to ground and the other wire to the parking brake wire from the unit. This will allow you to switch the supply on the wire to ground when needed.
Also, in some older Kenwood units you could just as easily connect the parking brake wire to ground and be done with it but, it does not always work.
SOURCE: i nedd ddx8017 bypass code
I need a unlock code for the kenwood ddx8017 dvd player the unit has locked me out
