Question about Canon PIXMA MP530 All-In-One InkJet Printer
PM530 printer: PGBK cartridge not working. Just
Cannon PM 530 printer: PGBK large black cartridge not working. Just quit working and using factory cartridges.
  • 4 Answers
Clean the feeder use Que tip With Alcohol only let it dry and clean the cartridge the same way replace the That should solve the problem, Also keep in mind if you are using a cartridge that is a refill The cartridge sometimes dry out Have that checked it might be bad other words plugged up. Good luck with it
Posted on Feb 22, 2009
Canon MP640 won't use pgbk cartridge
its maybe air leak to cartrige.check the hole on cartridge must closed.then clean head by printer propertis .cleanhead for 4 or 5 times
Oct 04, 2017 | Canon MP640 All-In-One InkJet Printer
My PGBK ink cartridge is not printing. I just replaced it. Everything else is working fine. I have done several cleaning jobs on it and the test prints that I print don't even show PGBK or the black...
the PGBK ink cartridge might not be getting a good connection you might have to remove it and check the connections or clean the connection bars
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you
might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Oct 21, 2011 | Canon Pixma iP4500 InkJet Printer
Just replaced the black ink PGBK on my Cannon MP810 printer and kept getting error msg "wrong printer head". Took printer head to World Cartridge and they cleaned but still get the same msg....
Dont go to Cartridge World :(. This problem is sometimes caused when a cartridge has been re-filled and re-set too many times, The chip corrupts and causes some very weird messages. Simply try a New Set of Cartridges (Not reconditioned or Refilled). GnL Products in NSW have new compatible cartridges for about $10 each. gnlproducts@live.com.au
Apr 04, 2011 | Canon PIXMA MP810 All-In-One InkJet...
Will not print text from computer (paper feeds
PGBK cartridge was totally blocked. Deep cleaning did not resolve block. Replaced ink cartridge (large black).
Feb 07, 2010 | Canon PIXMA MP160 All-In-One Printer
Canon PIXMA MP500 New Black ink cartridge produces no ink
If you don't use it very often the black could have dried in the printhead, and you will need a new one. Another possibility is that the purge unit is not cleaning and priming the printhead properly. I have seen several defective purge units. For 1 year it can be replaced under warranty, after that it is a $90.00 repair job in the shop.
Jun 25, 2009 | Canon Pixma MP500 All-In-One InkJet...
Why two black ink cartridges?
The larger of the two cartridges is used for text only. The smaller is used for color printing. Its purpose is to eliminate the need for a "Processed" black (black being mader by the color inks).\
Don
May 30, 2009 | Canon MP610 Photo All-In-One Printer
Black ink
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Oct 13, 2008 | Canon MP610 Photo All-In-One Printer
Canon MP500 PGPK cartridge wont print
i have the same problem too. This is obviously a product defect. If Canon not fix it, i wont buy Canon printer anymore.
May 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
526 people viewed this question
old marine
old marine
