Question about Lenovo IdeaPad Y510 - Intel Core 2 Duo 2.0GHz Notebook Laptops
My lenovo it keeps shutting down
When i plug in the charging cable in my lenovo it keeps shutting down why
  • 530 Answers
Hi im josh in cebu phils. may i help you? Friend i encountered the same problem of yours before.and i was able to solve it. Friend the rechargeble battery/supply of your notebooks is the problem.change that with the new one. or before you do it try to see first if the connections are ok like loosening connection may cause these problem. dmage power chord may aslo cause or the socket of your note try to check if not loosen or weak or detached. good luck!
Posted on Feb 21, 2009
Power schemes battery
Chances are that your battery doesn't / wouldn't hold a charge anymore. The laptop runs off battery power. When it is plugged in, the AC power "goes right through the battery", to support the laptop's operations. When the power cord is unplugged, and the battery doesn't hold a charge, the laptop will shut down, as your battery is (too) low to continue supporting the laptop's operations.
The easiest way around this problem is to get a new battery for the laptop.
If your battery is (quite) new (and a Lithium battery), you may wish to see if you can "revive" the battery's "life" ... first by depleting the battery (completely), then charging it (until it shows it is full, plus a couple more hours), and repeating this process a few times. If you're lucky, the battery will slowly/gradually start to hold some charge, but, don't expect it to be very long.
The (preferred) way to use re-chargeable batteries is to charge it fully, unplug it from the external power source, use it until it is depleted, then plug in the external power source to charge it up (fully) again .... and NOT to keep it on a power source all the time.
Oct 26, 2013 | Lenovo G500 59373039 Intel Core i5-3230M...
Laptop plugged in but not charging
Does the battery get hot when it is on the charger. Possibly a bad battery.
Sep 10, 2013 | Lenovo Computers & Internet
My Lenovo ideapad z370 keeps shutting down and booting up for no reason?
dude .,, its due to overheating caused by busted heat sink... maybe you should replace it to fix this thing...
Jan 02, 2013 | Lenovo Computers & Internet
Lenovo y550 laptop, battery shows fully charged, everytime i un-plug the charger,system shuts down, and won't start back up until i plug it into an outlet
Quite simply, the battery is dead. What is happening, is that the battery is charging, but the cells cannot retain the charge and it drains straight away. You need a new battery
Jun 16, 2011 | Computers & Internet
Lenovo 0301jdu keeps beeping when plugged in
Depending if the computer will turn on correctly or not, it sounds like this could be either simple or a big job.
To make it easy: If the computer turns on fine, works fine, just beeps while shut down and charging, there's a fault in the charger.
However, If the computer will power on, but no display yet you hear beeps, than one of 2 things is happening.
1: Try removing 1 chip of memory (1 of the panels on the bottom laptop) than starting it, than reversing the procedure.
2: If still no luck, the motherboard needs replacement which if under warranty is covered.
May 24, 2011 | IBM Lenovo ThinkPad Edge 15 0301EDU...
Lenovo G550 battery shows fully charged but when you unplug the laptop, the laptop shuts down and will not start up again until power cord is plugged back in.
Shows a clear indication of the battery to be faulty. So in the first place remove the battery and checck the voltage, now keeping the battery off the laptop, plug the adaptor to the mains, Now checck the voltage in the battery terminals which is in the battery compartment. If voltage is present then the battery is bad as it is not charging.
However if there is no voltage then the main board has a fault in the charging section which must be looked into.
Oct 28, 2010 | Lenovo 3000 N100 0768 - Pentium Dual Core...
My lenovo T400 will not shut down even when all applications are closed. I have to manually shut it down with the power button
Hi guest, try to turn off the pc by using the power button. Then remove the cables and battery on the laptop. Then push & hold the power button for 5 seconds. Reinsert the cables and battery then turn on the pc.
Check if you will be able to shut down your pc using the operating system..
May 15, 2010 | Lenovo ThinkPad T400 PC Notebook
Plugged in not charing, power available 92%
Shutdown PC. Then remove battery and Plug in AC power cable. Boot Computer. If everything fine, then shutdown again>put battery back and try! It should work. I had similar problem.
Jun 18, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Keeps shutting down.
The solution is found! There's no need to format your HDD
So.
- Unplug the battery;
- Press and hold the reset button for 20-25 sec;
- Put the battery back to it's place;
- Charge your device (when you plug the cable in, it turns on (note that a blinking lightning icon appears on the charging indicator), then it turns off with it's "shutting down" message, dont pay attention on this, just let it charge for about 10-15 minutes (note that the CHG bulb won't be lit));
- Turn on your device. The CHG bulb is lit, Archos doesn't shut down
- Enjoy
Jan 08, 2008 | Archos 504 500870 Digital Media Player
Lenovo IdeaPad Y510 - Intel Core 2 Duo 2.0GHz Notebook Laptops  Logo
383 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
