Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Bought a refurbished computer and when i started it up just gave me a message that said disk boot failure insert disk how do i fix this
  • Mike McWhinney May 11, 2010
    Is there a hard drive included with your PC? I would open up the case and do a quick check. If there is no disc drive, then you will have to buy one. Was it supposed to come with an OS?
  • Microsoft Master
  • 13,433 Answers
Hey,
do you have a CD in the drive or a FLOPPY? Remove them and try to start up again.
If you don't have a disc in the drive and you still receive this error, then the windows installation is hosed and you will need the windows installation cd or recovery media for the computer to reload the windows to the computer in order to fix it.
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 21, 2009
When I switch on my pc,it tells me disk boot failure insert system disk and press enter. I have XP proffessional sp3 but only have a xp home disk.
If your computer has just been formatted, your computer might require you to insert the boot CD
to be able to run it. You might hence get the error message Disk Boot Failure- Insert disk and
press enter displayed on the screen every time you will try to run it. This might be linked
to:
* 1. The boot options not correctly set in BIOS
* 2. A non bootable CD is found in your CD drive
* 3. You do not possess any bootable device
* 4. You have installed a new hard disk
* 5. The hard disk is not properly plugged
* 6. Your system files have been infected
Get more help and information for Disk Boot Failure. Hope this helps you....
Jan 29, 2011 | Microsoft Computers & Internet
System restore disc 1 erased & overwrote hard drive. Second disc won't start. All i get is a lengthy paragraph that boils down to : MEDIA TEST FAILURE, CHECK CABLE. PXE M0F: EXITING PXE ROM.\r\n ...
Your computer is using the network-connection to try to connect a "network boot server", to try to load a bootable image across the network.
The 'MEDIA TEST FAILURE, CHECK CABLE' is the error-message when no "network boot server" responds to a "network boot request".
The 'EXITING PXE ROM' message is the exit from the P(re) (e)X(ecution) E(nvironment) part of the R(ead) O(nly) M(emory) inside your computer, since the "network boot" did not proceed.
So, insert "Restore Disk #1" and restart your computer, and FORCE it to "boot" from the CD-ROM device -- not from the disk-drive. When prompted, insert "Restore Disk #2" to continue the reinstallation of Windows. When prompted, remove the disk from the CD-ROM device, and restart your computer.
Note that it's also possible that your disk-drive is "dying" -- any attempts to install Windows on it have FAILED. Thus, any time to "boot" from those "not-written" files will cause problems.
Dec 28, 2010 | Toshiba Satellite P205D-S8804 Laptop
Hi. Well there are not any reason for this problem to appear. Done nothing regarding disk problem. Anyway when I boot the process stops with the black screen with "Verifying DMI Data...... Boot from...
Make sure you dont have a floppy in the floppy drive inserted.
Also if you have a jump drive installed, plz unplug it.
But if you little computer savy. Go to your bios and make the boot sequence to first boot the Hard Drive
May 24, 2009 | Foxconn G31MX-K socket LGA775 motherboard
Disk boot failure
Technically you can copy all the data from one to another hdd but not the operating system
You have to install your operating system (windows, linux or MAC) on your new 500gig hdd and then copy your data from 60gig hdd.
Regards
Jan 22, 2009 | Avanquest DISK COPY & CLEAN (WIN...
When I start my Computer the On Screne message is Boot failure. Insert Boot Disc into A and Press any Key. I have tried to install Windows XP Pro but when the files are installed and i press enter,the...
It looks more like hard disk failure.
If your PC is still within the waranty period, kindly contact your PC vendor to fix the problem for you.
If the warranty period has already expired, please switch off your PC and remove all power sources and open up your CPU and check if the hard disk cables and the power supply is fine. Also check if there is any loose connection.
This should fix the problem, else please provide more details.
Jul 24, 2008 | Computers & Internet
Disk boot failure
sounds like a hard disk drive problem. If you are comfortable with working inside your computer, you can open the case and remove the cables to the hard disk, and re-connect them again firmly.
Jul 07, 2008 | Computers & Internet
Boot error message
Do you have a disk inside your floppy drive? If you do, remove it and try to boot your computer again.
Do you have a USB hard disk connected? If you do, try disconnecting it first.
If those two things don't work, you will need to have your computer checked by a technician. Maybe there is a problem with the hard disk or with the BIOS configuration (boot sequence).
May 28, 2008 | Computers & Internet
Consustently get "DISK BOOT FAILURE _ INSERT SYSTEM DISK AND PRESS ENTER" message
use xp sp2 bbootable disk and simply run a repair installation it should heal your system
Oct 17, 2007 | Mach Speed (MSNV-939) Motherboard
Disk boot failure
After making 100% sure you have no diskette or CD in any drives the conclusion may well be that the disk is ruined. You ay try to boot from a diskette or CD and see if you can access the disk then. (see www.ultimatebootcd.com for instructions to make a boot CD) "The ultimate boot CD" has a few tools that might help you out. Since you can't boot you must make it on a different computer, though. You may also try to insert the disk in a diffe rent computer to see if it can be booted there. Also make sure all cables are properly connected.
Apr 03, 2007 | Acer (91.AB033.041) 73 GB Hard Drive
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
26 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
