Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Poured water into the bean hopper by accident
My husband accidentally poured water into the bean hopper. We dried things up immediately. Can we run the machine after we let it dry to a while?
    Scholar:
  • 70 Answers
I wouldn't recommend it. Grinder needs to be opened up from the top where the ceramic blades are and that section needs to be cleaned out. The coffee in there will compact and mold quickly. Just unscrew the top screw by the hopper. There should be a rubber circular housing you can remove. From there set the grinder setting to the coarses setting (all the way to the right, and not 1.) Look at the blades and there should be markings in red and blue, align the red with red or blue with blue until the top blade easily detaches. Clean inside the that area and **** out all the coffee. Replace top blade, set red to blue so it locks the blade in place, replace arm and hopper.
Posted on Jun 09, 2009
Ground container light
Either you mean the coffee ground low warning is lit OR the GFRI oulet has tripped out?
* Dangerous stuff first! Unplug machine Immediately. (there may be other machines on same line that needs power and someone is bound to reset the power thus shocking anyone touching the brewer.)
* Check for water leaking from body of machine (brew basket okay) Call vendor for service. Do not use brewer till they check it.
* Low beans in grinder hopper. If you have a full hopper but the low bean warning is still lit then it's probably due to something blocking the sensor. Remove beans and hopper. Clean and wash hopper of oil and coffee. Dry, re-install and check, low bean light should still be lit. Pour in beans while watching light. It should go off by the time it's 1/3 to 1/2 full.
* Still not working? Call your vendor for service. Be Safe, Call for service anyway.
Aloha, ukeboy57
Jan 17, 2018 | Coffee Makers & Espresso Machines
Poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
I accidently poured milk into the glass pitcher when the bottom blade/cap was not on! it went thru the motor unit... I am trying to dry it - what to do? let it completely dry over some hours before trying...
I think that you need to flush the unit with water, I would take it apart, then let it dry COMPLETELY before plugging it in....I suspect that the unit will not be damaged.
Mar 04, 2011 | Breville BBL550XL 5-Speed Blender
I accidently poured about half a cup of water into the bean hopper. Now it still grinds beans but it will not start to cycle (the bean light does not turn off). Can i take it apart and dry it out or...
Taking the grinder apart is not easy to do and get it back the way it is suppose to be is not easy. The first thing I would do is turn the big knob to the 18 or max and the small knob to the -, and try again. If that works leave it there for a couple shots to clean everything out. If that works continue. Then while the grinder is grinding, turn the big knob back down to 8-10 and make some more drinks. 6 to 8 is a good start.
If it didn't work you will need directions but the damage may be already done. The burrs ghave no coating on them and they can rust very quickly. you may need new burrs or a new grinder.
I have a saying " If you are working on the water, keep the bean hopper covered and vice versa". Cross contamination will damage the machine very quickly.
Nov 08, 2010 | Solis Palazzo Espresso Machine
All of sudden my grinder plugs up. coffee settles in around the base of the burr and does not seem to fall into the grind bucket, so the machine still runs but grinding basically stops as no more more...
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Nov 03, 2009 | Solis Maestro Electric Burr Grinder
Poured water into coffee grinder
easiest thing to do is put it outside to dry or use a blow drier to dry it up, it should be ok
Jul 01, 2009 | Saeco Magic De Luxe Espresso Machine
I accidentally poured a gin on it
easy fix dont try to turn it on just put into a bowl of rice and cover it leave it in rice for 3days and try again this will soak up water and system should be dry enough to start back up just dont keep trying to tuen it on or you will fry the system leave it alone for 3-6days or untill fully dry and no water visible put in bowl screen down so water can run out of system
Jan 09, 2009 | Sony PlayStation Portable (PSP) Console
Help....we poured some water into the bean grinder/container
You have to take off the bean hopper, turn the ring on grinder anticlockwise to you see the claque. Take out the middle off the grinder and clean everything carefully.
After that you have to put it back again, when you have the middle off the grinder back you turn the ring clockwise to the end, after that you turn it anticlockwise 14 "tick".
Sep 04, 2007 | Saeco Magic De Luxe Espresso Machine
Coffee Grinder not working
the grinder is most likely stripped and needs to be replaced:-{
Jul 23, 2006 | Saeco Caffe Charisma Espresso Machine
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
216 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
