Question about Home
Hooking up a GE Model GXRM10G Reverse Osmosis to ice maker
Trying to hook up a GXRM10G Reverse Osmosis Filtration System. What line do I tap into to to run to the ice maker?
  • 547 Answers
Cold water line
Posted on Feb 21, 2009
Water filter drain running all the time
Is this a new system? The should be a small restriction in the drain line. The size of the restriction is matched to the gallon per minutes of the R.O. system. Yours could be missing or not the right size, ie not enough restriction.
Jul 02, 2012 | General Electric GE SmartWater Household...
I have a GE smartwater reverse osmosis system model number GXRM10GBL02. Water leaks daily from the small hole on the faucet on my counter top. Any idea why water comes out that small hole? Otherwise the...
That is the drain for the reverse osmosis system. You have what is referred to as an AIR GAP faucet. The waste water is pushed up there before it goes to drain just as the drain for a dishwasher does. If water is coming out of the faucet the drain is most likely plugged or the line is kinked causing water to back up and overflow. Check the drain line for kinks and clean out the drain where it attaches to the stand pipe.
RJ
Oct 22, 2010 | General Electric GE SmartWater Household...
Sink tap has overflow going directly into the drain and constantly running. This is a reverse osmosis system that is outside warranty.
If you mean the little weep hole on the tap is leaking? If so, then the drain line connected to the sink drain is clogged. Remove this line and see if it's draining free.(have bucket ready) Most likely it will be where it enters your sink drain at that fitting, clogged with sink drain materials.
Jul 17, 2010 | General Electric GE SmartWater Household...
What line do you tap into to add an icemaker to a GE Reverse Osmosis water system?
If you want the reverse osmosis water to go to the ice maker then you tap in to the line that feeds the spiget on the sink.
Mar 03, 2010 | General Electric Profile Smartwater Ultra...
Ice Maker Not Working
Hi: A lot of reverse osmosis systems don't supply enough water pressure to the ice maker to fill. Contact your manufactrue of your reverse osmosis system and see if it works with icemakers. I thind usually the require at least 20-30psi. Or hook your refrigerator to city pressure to see if it works. Also I don't know if you have just an ice maker or a water dispensing side by side, or your water quality. If you just have an icemaker, most chlorine will evaporate before the ice is frozen, any odors in the water will still be there. Good Luck, Jeff
May 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Side by side refrigerator
The ice maker is not producing ice or not enough ice
production.
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
 Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Home Logo
878 people viewed this question
Top Home Experts
Donni Steen
john h
Are you a Home Expert? Answer questions, earn points and help others
