Question about John Deere Garden
Wilbert612@earthlink.net lawn mower will not crank over change the switch relaystill willnot start or crank.
    Problem Solver:
  • 8 Answers
Sounds like a faulty safety switch somewhere... maybe the neutral switch or the clutch switch.
Posted on Feb 21, 2009
My john Deere 110- 42" cut lawn mower ran out of gas and won't crank back. Noticed the parking brake is engaged but will still roll. What is my problem?
Hi Shannon, It's either fuel OR electrical, First check electrics, If it cranks but not starting......
How to test a solenoid....
How to test lawn mower solenoid
How small engine governors work....
How Small Engine Governors Work any governor setup
How to test lawn mower electrical safety switches....
Shows all safety switches disabled....
Disable all lawnmower safety switches
Apr 29, 2016 | John Deere Garden
I have a cub cadet lt104 and we replaced the battery and solenoid and it won't start
wont crank or wont start. 2 different things...
wont crank, in this order: check fuse, brake switch ( adjustment and operation ) and then ignition switch
wont start but does crank: check for spark, yes then check fuel shut off solenoid. no, disconnect kill wire to coil and check again, still no, coil is issue, if yes after disconnecting kill wire suspect a safety switch
May 16, 2014 | Yard Machines 155 Torque Briggs Stratton...
I have a cub cadet lawn mower 1550 it wont start i change the solinoid and checked everything i can think of keyswitch safety switch on clutch oil pressure sending unit it dont seem to be letting any
If it is cranking and not starting, check the switch on the bottom of the bowl. Those go bad I just recently changed one. If that is not it than please explain a little more. your paragraph ended abruptly.
Oct 18, 2012 | Garden
Ran over metal coathanger, mower stopped ,removed coathanger and mower will not start, whats wrong ?
Souns like it may have sheared the flywheel key, this is a failsafe to stop it bending the crankshaft, remove the flywheel and check the key, it is alluminium, you may need a special puller to remove the flywheel as it is on a taper.
Jun 09, 2012 | Craftsman Garden
When I try to start it with the key start it will not turn over changed fuse but still no start. How do I check the starting system?
What you probably have is either a bad connection to the starter, or switch, or you have a faulty starter, or battery. I would start by checking the wires. Take them loose and reconnect them. If that is to no avail, then you will want to have the battery and starter tested.
Mar 16, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Lawn mower wont start. changed air filter, spark
Does it turn over? If it does, what happens? Does it sound normal when its cranking? I need more information to help. Is it a push mower or riding mower? Does it start by key or pull start?
May 01, 2010 | Poulan Garden
How do I change the gas tank on my John Deere L110 Lawn mower
Howdy, I have a jd L110 automatic with 179 hours on it...some times when starting with the brake held down it will not crank...some times it will... I am not sure if it is the switch on the brake or the starting system...Is there any way with out buying a new switch to wire jump the switch to see if it is in the switch or not? thanx, Dan
Oct 16, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
My lawn mower cranks but wont start I have
The magnets are fitted in the flywheel under the pullstart engine cover but i dont think thats your problem. It sounds more like fuel trouble. Remove and clean out the carb. and maybe renew the diaphram.
Sep 05, 2009 | Garden
Motor willnot start. clicking noise when i try to start it. the battery is good and i jump started it with my car--started great. i have cleaned the posta and cables
the problem is the starter cylinoid . this is going to set you back about 10 to 15 dollars.
or it could be your starter trying to go out, it will crank off your car battery because you are using more amps to crank it..
a car battrey has more cranking amps than a small engine battery..f.y.i.
Jun 24, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Lawn mower will not hold charge with new battery sometimes starts sometimes no l 120 john dear mower I change my alternator, but it was not turn the fly wheel. what I did wrong
Often mowers come with batteries which simply do not have the cranking amps to do the job. Have someone look at your mower and see if your attery has the sufficient cranking amps.
May 28, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
178 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
