Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet series washer spins really slow
It works in all the settings but its very slow and will not spin out the water
    President:
  • Whirlpool Master
  • 2,651 Answers
No high spin speed will ever be acheived if the water cant drain out,, remove th elower acess panel (3) screws acros the front of unit, from there youll see a drain clean out, unscrew the plastic and remove the dbris,, BE WARNED THER EWILL BE WATER BEHIND THE SCREWOUT DRAIN PLUG!!!!! i usually grab a trash bag and hold under to catch the gallon or so of wate rthat will come out
Posted on Feb 21, 2009
WFS1073DD front load WASHING MACHINE Everything works but will not spin fast enough to spin the water out. It spins very slow
Early automatic washers used a motor with multiple windings to provide the various speeds required by different parts of each wash programme. Modern washers use an entirely different sort of motor and the speeds are selected and controlled electronically with feedback to ensure the speed is correct.
I suspect the problem is the electronics - the part of the programmer and controller that regulates the motor speed but you should check the motor and motor brushes, the drive belt and all electrical connections as a matter of best practice before you spend money...
Aug 13, 2017 | Washing Machines
During spin cycle the drum fills with water and spinning slows or stops completely. I will then switch machine off and on again. Then it drains only for a little while b4 above start again. Plz help
Hi
Do u drain it 1st before u switch it off? If u just keep switching it off and on again there will be more water than usual which will probably slow the spinning down.
Drain the machine
Remove or open the vent at the bottom of the machine
Get a towel and a large baking tray or something similar
Place the towel underneath the vent and the tray to catch the water
Turn the filter slowly until u see water coming out, when the water slows down pull the filter out.
Clean out whatever is in there and replace the filter
see if this works?
Oct 04, 2015 | Washing Machines
AWO/D 4505 not spinning
does it pump out all the water when it spins the first time? when they spin slow sometimes the pump is not pumping out all the water causing it to spin slow.
May 15, 2014 | Whirlpool Washing Machines
Spins slow, does not drain and leaks a little.
SOUNDS LIKE MIGHT BE SEAL LEAKING WILL NEED TO DO BEIRINGS AND SEALS
Jun 17, 2012 | Maytag LAT2300 Top Load Washer
The Whirlpool duet washer I have is a WFW8300SW. The problem I am having is that now when it goes into spin cycle I don't think it is spinning as fast as it should be. How can I fix this?
Most common to cause slow spin is slow draining. Remove the lower panel (3 screws) and remove the pump filter. It simply unscrews and can be cleaned of debris to facilitate fast drainage and good spinning results. Be sure to have a few towels handy to catch the little bit of water that remains in the lines when you unscrew the filter.
Jan 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer is not retaining any water it all goes out the drain hose also i set it to spin and it made wierd noises and spins very slow
the hose where the water flows out is too long - it is siphoning out - I had this problem - when we first installed out maching
Dec 19, 2010 | Kenmore 22422 Top Load Washer
I get the error code S02 on my Duet washer. It
02 is a slow drain,
yopu can check your pump
take off the back wall and hoses,, have towels ready
you will loose water,,
inspect the inside of the pump and all hoses
Oct 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer not spinning
It's not really a solution but I checked my paper work from when I purchased the washer and found out that I got the extended warranty, so I have called in a service call.
Jun 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Spin speed slow
Sometimes this is a problem with the drain pump filter. It will get clogged with debris which will cause unit to spin slowly. The panel at the front bottom of unit will grant you access to the filter on the pump. Get a bowl or bucket and get ready to catch some water. Good luck
Jun 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
835 people viewed this question
Dan Webster
Dan Webster
Sal De
