Question about Linksys Wireless-G WRT54G Router
Cannot get the drop downs to work to enable security
I want to enable security on my linksys router page but I cannot get the click down to work on any of the pages.
    Problem Solver:
  • 10 Answers
I used to have the same router but upgraded to the wireless N model. What I didn't like about this router is you could enable security from a button on the router itself. Frankly, either you use security...or not. This on/off feature is for the birds.
I use macaddress filtering and don't like WEP. There were a few times that I accidentally or inadvertently enabled WEP at the router. Not desirable....and it also would lock out many of the administrative features on the intranet page.
I would reset the router. Go to your local router IP at:
http://192.168.1.1/
Posted on Feb 21, 2009
Security mode not working
you have to save it after enabling it.the save button is at the buttom of the screen.
Oct 17, 2012 | Cisco Linksys WirelessG Broadband Router...
How do you enable security for linksys wireless routers
  1. Type "http://192.168.1.1" into your Internet browser, and press "Enter."
  2. When login page opens up, type the username and password for your wireless router.Depending on your router brand, you may have "admin" and "password" as the respective default username and password. But again, you must refer to your wireless router support manual.
  3. Once logged in, click "Wireless Security" and Select "WEP" as the security encryption type
  4. Set the default transmit key to "1".
  5. Type in a passphrase and click "Generate". This generates random passkeys.
  6. Note down your network's SSID (listed on the security page) and the first WEP key. This is the information that you will need when trying to allow new connection through the wireless network.
Aug 22, 2012 | Linksys Computers & Internet
My wireless router has dropped it's security code. How do I reinstall the security code so other people cannot log onto my router.
Hello
You can do a factory reset.
1 unplug all cables to router.
2 Hold down small reset button behind router,use a pen tip to hold this button in for 30 seconds.
3 Reconnect cables,power cable first.
5 once all lights are on log into router and go to wireless security page.Make sure wep is checked and active.
There you can change your key,write this number down for future.
Once done click apply.router may restart again.
This will resucure the router.
Oct 13, 2011 | Linksys Wireless-G WRT54G Router
I need to change my linksys routher password how to change?
Hi Friend,
If you want to change the password for router login page then please follw the steps:
1. Click Start \ Run\ type cmd and hit enter
2. In the black window typ the command ipconfig and hit enter.
3. Note down the default gateway and close this window.
4. Open the web browser and type the default gateway and hit enter.
6. The default password is admin and leave the username blank.
7. In the router setup page click Administration
8. In the left pane you will see Router password. Type the new password and re-type it. Then click save settings and turn the oruter off for 30 seconds and then try to login with this new password.
If you want to apply security on your router, so that no one can use your network, then please follow the steps:
1. Open the web browser and type the default gateway and enter the password.
2. Click Wireless and then Wireless Security.
3. Select WPA Personal from the drop down of Security mode.
4.WPA Algorithm should be TKIP
5.Type any ten digit number as the Shared key and note it down and click save settings.
Turn the router off and switch it on. Now whenever you try to connect your wireless devices use the shared key as the security key.
I hope this will resolve the issue.
Regards
Chiranjeet
Dec 14, 2010 | Linksys WRT54G2 Wireless Router
Some one get into my linksys rouder and set up secrity code and now i can not get into my rouder . so please can you help me get rid of thiold secrity code and so i can set up the newer code so i can use...
If you don't know the password, then you need to reset the router,
Hold it down the reset button with the help of a pen point and power cycle your router. Then re-do the configuration following the manufacturer's instructions. Then you can set password for your router.satheeshd_0.jpg
Nov 05, 2010 | Linksys Wireless-G Broadband Router
How do you remove a security code from a wireless router?
Disabling wireless security key on the router. Just follow these steps:
Step 1: Access the router's web-based setup page.
Note: For Linksys default ip address 192.168.1.1: default password
Step 2: On the router's web-based setup page, click the Wireless tab then click the Wireless Security sub-tab.
Step 3:Click the drop-down arrow for Security Mode and select Disable and save settings.
Nov 04, 2010 | Linksys Wireless-G Broadband Router
How do I put an encryption on my linksys router?
Securing your wireless network is a simple process, which generally does not require a lot of time. This can be done by:
  • Enabling WEP or WPA on the Router
  • Enabling Wireless MAC filter on the Router
  • Disabling SSID Broadcast on the Router
NOTE: The wireless security modes available may vary depending on the model of the router and wireless adapter you are using.
Enabling WEP on the Router
Wired Equivalent Protocol (WEP) is a type of wirelesssecurity which does not change. It provides comparable confidentialityto a traditional wired network. There are two types of WEP you canchoose from:
a. WEP 64-bit: This type of WEP consists of 10-hexadecimal codes. To enable WEP 64-bit, click here.
b. WEP 128-bit:This type of WEP consists of 26-hexadecimal codes hence it is moresecured compared to WEP 64-bit. To enable WEP 128-bit, click here.
Enabling WPA on the Router
Wi-Fi Protected Access (WPA) is a type of wireless securitywhich is dynamic in nature. Meaning, it changes depending on the timerenewal you will specify. Hence, WPA is more secured compared to WEP.
  • Temporal Key Integrity Protocol (WPA-TKIP) – utilizes a stronger encryption method and incorporates Message Integrity Code (MIC) to provide protection against hackers.
  • Advanced Encryption System (WPA-AES) – utilizes a symmetric 128-bit block data encryption
To enable WPA, click here.
Enabling Wireless MAC Filter on the Router
Wireless access can be filtered using the MAC address of thewireless devices transmitting within your network’s radius. You caneither permit or prevent specific wireless computers access to yourwireless network.
To permit wireless computers to connect to your wireless network, click here.
To prevent wireless computers to connect to your wireless network, click here.
Disabling the SSID broadcast is one way of securing your wirelessnetwork. This procedure will prevent other users from detecting yourSSID, or your wireless network name, when they attempt to viewavailable wireless networks in your area. For instructions, click here.
Jul 11, 2009 | Linksys Wireless-G WRT54G Router
How do I make my connection secure to the internet? I have linksys wireless-G 2.4 GHz broadband router. The router is all hooked up but I believe the current connection is unsecured.
When you connected, did it ask you for a password? If not then it's obviously unsecured. Here's how to fix that... i have the same router.
On XP... open internet explorer... in the address bar, type in: 192.168.1.1
On vista.... click start menu...click on network...right click on router and select properties. Next, click on the "Network Device" tab at top of the new window. You will then see "Device Webpage"... click on the ip address to the right of that underlined in blue. It should ask you for a password... if you haven't set one manually the user is admin and the password is also admin. I recommend changing that to a manual password ASAP. Ok, after logging in, now you have the router's set up page in your web browser.
To make it secure:
On the set up page you now have open... you have a few selections that act like tabs: Setup, Wireless, Security, Access Restrictions, etc... Click on Wireless. After clicking on that, you have some tabs underneath wireless you can click on now.
Those selections should be: Basic wireless settings, Wireless security, Wireless MAC Filter, etc... Click on Wireless Security. There you should see disabled on the first drop down. Pick a WEP, WPA or whatever you prefer. I personnally use WEP with 64bit 10 hex and for the password, i use a 10 digit number.
After you have set up your password and security, click save settings at the bottom. After it's done processing the save, you can close the web browser. You are good to go now.
By the way, I recommended changing your password to access the router's set up page. Make absolutely sure you save that username/password in a safe location. If you forget it, there is nothing linksys can do to help you. I know from experience unfortunately.
Hope all this helped... Good Luck
Jul 02, 2009 | Linksys Wireless-G WRT54G Router
I am not able to get on to the internet with my wireless laptop
In you web browser, type in 192.168.0.1. If that doesn't work, try 192.168.1.1. If none of these work, it is your router that is the problem and you need to contact Linksys directly. A dialogue box will appear asking for a username and password. Leave the username field blank and type in admin for the password. You will reach the linksys configuration page. Scroll down untill you see Local IP Address. Change it to 192.168.2.1. Scroll down and select save settings. Relogin back to the webpage. Click the tab that says wireless. Make sure the wireless broadcast option is enabled. If it isn't, enable it and click save settings. Click the subtab that says Wireless Security. Change the first option to WPA Shared Key. Changed the second option to TKIP. Next, type in a password you are sure you will never forget. Write it down if necessary. Once completed, hit save settings. You should now be able to set up the wireless connection on the laptop successfully. If you need help in doing that also, please comment back.
Dec 24, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
