Will not stay running. It will start and idle but give it gas and it shuts off.
fast foot it still stalls, bravo that, 1st post ever with that key fact.
very very observant.
stalls, even with fast right foot.
and never runs right, correct?
no engine options stated to all answer drop to generic.
a tune up, do the 60k now.
if the engine has a timing belt , nows the time.
if compression is good, over 150psi, then
bad spark, tune it up.
if spark is good, and timed right,its a fueling issue
EFI is your system for injections.
we check the fueling for dry or under fueling. or flooding
those are 2 different paths. there.
lite me guess, its Under fueling.
ASE ways) I add propane gas, to the intake
i gain power, opps it really IS underfueled ( a 1min flat tests)
so why>
ok, low fuel pressure is 1st.
i check my rail pressure 1st.
at spec> no its low then the reg is bad, (stuck wide open )
the fuelpump voltage way low, ?
or the filter clogged, sure 60k tuneups do work , and my filter is new
and the pump is weak and bad
. just one example.
if pressure was good, id do the injector leak down test
then the balance test.
all that is in the FSM. every tests.
and will find the cause of gross engine power loss.
all with on lil old $20 fuel pressure gauge>
ask for details can do that at each step.
