Question about HP Compaq Presario v3000z Notebook
Laptop powers up and shuts off - HP Compaq Presario v3000z Notebook
  • RescueTechLA
    RescueTechLA May 11, 2010
    How far does it power up? When did this start?
    Scholar:
  • 51 Answers
Hello there I understand your Notebook shuts down after you turn on the power.
To isolate the issue, please perform these troubleshooting steps.
1) Power Drain :--- Static electricities some times cause your Notebook not to boot. To remove static electricities use power drain. Follow below steps for power drain.
a) Shutdown the Notebook. b) Disconnect any power source (i.e., AC adapters) c) Remove the battery from the CPU. d) Hold down the power button for 30-60 seconds. This will remove any static charges. e) Connect the battery back and power on the Notebook.
If the above method does not work. Follow the below one.
2) Your Notebook Compaq Presario v3000z is having a manufacturing defect, if you still experience the difficulty, HP is arranging a "Limited Service Enhancement" plan for your Notebook. HP may service your Notebook even if it is out of warranty.  For more information contact HP.com 24X7 chat support, they will assist you better in providing you the procedure for shipping and details. You can log on to the HP chat support by clicking the below link or copy and pasting it in the address bar of a web browser.
http://welcome.hp.com/country/us/en/contact/chat_1.html
To check the Limited service enhancement plan and information about the defect of the Notebook v3000z clic the below link or copy and paste it in the address bar of a web browser.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Thank you
Take care and bye Raviteja
Posted on Feb 21, 2009
My laptops shut down when i put the adapter and doesn't get start up , but it's work normally with betray
Problem description:The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause:1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution:First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Reference: http://www.chargerbuy.com/blog/laptop-shuts-off-when-ac-adapter-plugged-in/
Sep 13, 2011 | Toshiba Satellite M205-S4806 Notebook
My toshiba laptop wouldn't work well when connected to power source but will function well am using the battery
Laptop shuts off when AC adapter plugged in
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
Possible troubleshooting steps and repair solution: First of all, test the power adpater. Make sure the apdapter outputs correct voltage. It's possible that the outup voltage is not correct and the laptop shuts down to prevent the damge. Test your laptop with anohter known good power adapter.
If the problem still exists, even after replacing the adapter, most likley it's the motherboard failure. Replace the motherboard
Jun 20, 2011 | Toshiba Computers & Internet
Shut down computer but some lights stay on
Your are not "shutting down" the laptop. It is going into "Stand-by" mode.
#1:
When you want to shut down,
select [Start]
then select "Shut down" and not "Stand-by"
The power button will also work.
#2:
Press the power button and nothing else.
The laptop will log you OFF and "shut down"
Nov 08, 2009 | Toshiba Satellite A135-S2386 Notebook
Power led remains lit at all times with battery or power plugged in. Fans turn on when powered on but no system response. Was able to get system to power on by compressing laptop above and below DVD with a...
ok you have laptop. Look for a key called "Fn" it should be around the ctrl or alt key on your keyboard. Try pressing that. After trying to turn it on and it wont. press the Fn key. The last time you were able to use the laptop how did you shut it down? Did you tell it by going threw the menu when logged on. Or just pressed the button? Or did you tell it to shut down then you closed the screen/lid before it actually shut down? Laptops will go into stand by after you tell it to shut down if you dont wait til it shuts down, before shutting the lid. ALso depending on the laptop company you have Trying to figure out which one it is. They have program installed with your system. And depending on how it's set up, will greatly effect how or even IF your laptop will shut down right.
Oct 10, 2009 | Gateway M675 Notebook
Laptop keeps cutting out
Lynda, your laptop is going to Standby mode, not shutting off. I'd suggest changing the power options. Go to: Start-Control Panel - Power Options - Power Scheme(Portable/Laptop should be selected) and change the settings. Good luck.
Jun 12, 2009 | Computers & Internet
Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
May 09, 2009 | Compaq Presario R3000 Notebook
Hi, my satellite pro laptop is powered up. I can not shut it off.
If the laptop does not shut down if you go to Shut Down, you can try pressing the power button and see if it shuts down, if not, hold the power button down for 5 seconds and it will power off.
Jun 24, 2008 | Toshiba Computers & Internet
HP Compaq Presario v3000z Notebook Logo
65 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
