Question about HP Photosmart C6180 All-In-One InkJet Printer
I can't figure out how to make my printer stay on grayscale or black print it always defaults back to color need to make numberious black only copies
  • 537 Answers
There should be a setting for printing preferences. Most printer drivers have these settings
Posted on Feb 21, 2009
Canon Printer MP250 doesn't want to keep the grayscale ONLY setting.many attempts to use only black ink but it keeps on setting color ink by default. SB001
If you are changing to greyscale before you print, it will only stay there for that print job. You need to go to the printer through the control panel - devices - printer and change it to greyscale. It should stay that way then.
Jul 03, 2015 | Canon Pixma MP250 All-in-One Color InkJet...
Lexmark Pro 905. How do you print a document in black only. I know how to make copies in black but I can't figure out how to print in black.
Go into the color control settings and pick Grayscale or B&W; if you pick grayscale be sure to test print and adjust print density so black doesn't look medium gray and the rest illegibly ephemeral.
Aug 06, 2011 | Office Equipment & Supplies
Change default to black printing only
here is what you will need to do to get this to work.
first while on the main copy screen change the setting from color to black like you want it.
then you will need to goto the additional functions button and under copy settings you will need scroll down to the second page.
there you will want to hit the standard setting button then click the store button, then click yes... now it will default to black copying.....
now if you want to it to print only in black you will need to go to the printer window in windows....
control panel-----printers----then select irc6800 printer
then right click on the printer icon and goto properties---- then printer perferences---- then you will need to find the color tab and set it to grayscale printing.. then click apply then ok and exit out.... now hopefully this will set your print driver to default to black and white.
sorry i don't have the drivers loaded on my computer for me to look at to tell you exactly how to change it
Apr 15, 2010 | Canon imageRUNNER C6800 Copier
I want to use black ink only and stop wasting color ink
Go to Control Panel->Printers. Then right click on your printer and select printing preferences. There you will see an option like Print in Grayscale or Black and White only.
However, please note that some printers although they are set to print in grayscale they also use the color cartridge and some even don't allow you to print in grayscale if the color cartridge is empty. Why is that? Manufacturer's way of charging you more money.
Feb 11, 2010 | Canon PIXMA MP470 All-in-One Printer
Hi, I have a Macbook running Tiger 10.4.11. I have yet to figure out a way to print in black and white from safari. HELP!
When you go to print (apple/p) and the dialog box comes up (lists printer, presets, copies, etc)
There should be a gray horizontal line across the middle of this dialog box. Note the drop down box that is on this gray line ... this is an important drop down box. When you select different items in this box, all the options underneath the gray line change.
The selection in this box is probably "Layout" by default. Change it to look at the different options, but as things change below the gray line don't get confused about which is the "main" selector drop down for changing all the options .. it's the one on the gray line ....
I'm using an HP printer, and when I select "Paper Type/Quality" in this drop down, I get an option under the gray line that says "color" -- the options in that box include the option for "Grayscale"
If I were to select Grayscale, then the printer will print only in black and white and shades of gray.
That's the easiest way to do what you want, and it will apply to any program you are printing from, since you are selecting "Grayscale" from the print dialog.
Look through all the different variables in the print dialog to become familiar with them.
If you often use one particular setting and don't want to have to go through the sometimes confusing search through the drop downs, since they change back to their defaults each time you print, then you can set a "Preset" - this will remember your settings and allow you to get to them easily ...
To do this, first select all the options the way you like them, for example you might select Grayscale under the Color option under the Print Quality section. Then, before you actually print anything, go the the top where it says "Presets" and do a "Save As" and choose a Preset name that will be meaningful to you ... like "grayscale" -
Next time you print, keep an eye on the preset - it may NOT go back to the default of "Standard." It may stay on the last-used Preset ... so keep an eye on it before hitting the print button.
Hope this helps!
For help with Public Address system feedback, and great AA speaker tapes and MP3 downloads, my website at rexark.com is a great resource!
Feb 08, 2010 | HP Photosmart C6280 Printer
Can't print in color on my Canon printer
If you go here you can download or view a manual for your printer, with detailed instructions on changing the print cartridge settings in windows or mac.
If you go here, you'll be taken to the home support page for your printer, where you can enter a search for "print in color", and detailed instructions will follow.
You go to control panel>printers>print preferences> and uncheck the grayscale printing and set the color to auto.
Issue: Image prints black and white instead of color....See below.
Solution: Uncheck Grayscale Printing checkbox (Windows)
Unchecking Grayscale Printing Follow the steps below to change the Grayscale Printing option:
  1. On the Windows desktop, click 'Start', point to 'Settings', then click 'Printers' (Windows XP: On the Start menu, click 'Printers and Faxes').
    For Windows Vista: Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
  2. Windows 2000/XP/Vista: Right-click the printer icon, then click 'Printing Preferences'. Windows 98/Me: Right-click the printer icon, then click 'Properties'.
  3. On the Main tab, click on the 'Grayscale Printing' check-box to remove the check-mark.
  4. Click the 'OK' button to save the setting.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 28, 2009 | Canon PIXMA MP460 All-In-One InkJet...
I just got a hp photosmart c4480 printer and it makes black and white copies, but I can't figure out how to print in black and white like when I am on a web site.
OK, Whe you select Print from the File Menu and the Print window opens, selct the Color tab.
There should be an option to Print in Grayscale. Check the box beside it and click OK at the bottom. Then back at the Print window, click Print.
(Note: If this option is not on the Color tab, or you do not have a color tab, look on the Advanced tab for the same thing.)
Need additional help...use the Comment link.
Thanks for using Fixya.
Apr 22, 2009 | HP Photosmart C4480 All-In-One InkJet...
Can I set default printing to black and white for color laser printer?
Yes. Any printer's default options can be set as desired. Open the printer's properties (Start/Control Panel/Printers/right click the printer and left click Properties), and change the setting as you wish, then click OK. Those settings should be used each time you use the print command, unless you change the settings for that particular print job.
Hope this helps, and please rate my advice, good OR bad.
Feb 05, 2008 | Office Equipment & Supplies
HP Photosmart C6180 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
