Question about Cherokee Jeep Grand CD Changers - 10-Disc
My check engine light is not working - Cherokee Jeep Grand CD Changers - 10-Disc
  • Anonymous Sep 03, 2015
    Sounds like might be one of the engine gauge sensors is bad.,check the fuses too might have a bad fuse.good luck.
  • 211 Answers
Wow this one is 1 year ago. bulb could have blown .if it was bought used. it might not even have a bulb.when you buy a car turn on the car but dont engage the starter .check engine should be on and stay on untill you engage starter and should go out in couple seconds after car starts. you probley already got it fixed by now any way im new and starting with check engine light your my first .
Posted on Aug 13, 2010
Can a blown cigarette lighter fuse make the check engine light come on
No, the problem lies elsewhere.
Get a diagnostic check done to identify the fault
My Engine Check Light Is Illuminated
Feb 09, 2016 | Chevrolet Cars & Trucks
Why can't I pass smog check engine light won't come on
The smog check requires a visual inspection of your check engine light. It has to come on for a bulb check at startup to make sure it's working. But, the light must go out after starting the engine(it cannot stay on after the engine starts during a smog check). If the check engine light fails either of these two tests, the vehicle will fail the smog check inspection.
You need to have the cause of your inoperative check engine light diagnosed and repaired.
May 31, 2014 | 2004 Chevrolet Blazer
I drove the jeep the day before and it was fine the next say i get in and the check engine light came on and was flashing and it was idleing (shuttering) what could this be?
To confirm the exact fault,the error code stored in engine computer module has to be retrieved.
But as why check engine light came up,for that issue there are few help link with solutions to correct the issue.========
Click the link below:---
After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure? http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
------------How to Read Codes from Check Engine Light? http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
------------Check Engine Light Reset Procedure? http://whoisbyme.blogspot.in/2012/06/check-engine-light-reset-procedure.html
------------- Check Engine Light ON? http://whoisbyme.blogspot.in/2012/06/check-engine-light-on.html
----------- Intermittent Check Engine Light? http://whoisbyme.blogspot.in/2012/06/intermittent-check-engine-light.html
---------- Service engine soon Light Turned OFF after Jump Start? http://whatisbyme.blogspot.in/2012/06/service-engine-soon-light-turned-off.html
---------- 2005 Chevy Impala: Service Vehicle Soon Warning Light? http://whoisbyme.blogspot.in/2012/06/2005-chevy-impala-service-vehicle-soon.html
--------- Malfunction Indicator Light ON http://whoisbyme.blogspot.in/2012/06/malfunction-indicator-light-on.html
--------- Car jerks while going uphill and Check engine light is ON?
http://schematicsdiagram.blogspot.com/2011/12/car-jerks-while-going-uphill-and-check.html
Toyota Camry Check engine light flashes while driving? http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-check-engine-light-flashes.html
----------1999 Toyota Tacoma: Check Engine Light Read Code P0171?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-tacoma-check-engine-light.html
2007 Toyota Highlander Hybrid: Yellow Check Engine Light ON dash? http://whatisbyme.blogspot.in/2012/05/2007-toyota-highlander-hybrid-yellow.html
--------Check engine light with codes P2195 and P2197? http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
---------Car Runs Fine But Check Engine light is ON? http://whatisbyme.blogspot.in/2012/05/car-runs-fine-but-check-engine-light-is.html
----------After replacing throttle body the Check engine light starts blinking? http://technoanswers.blogspot.com/2012/01/after-replacing-throttle-body-check.html
---------OBD Code is cleared but check engine light will not RESET? http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
--------These will help.Thanks.
Nov 22, 2012 | 2002 Jeep Grand Cherokee
Electrical problems with a 2002 Satun SL 200, the electrical door locks dosn't work, the mirror adjustments dosn't work, the dome light dosn't work. The engine runs good. head lights work
check all your fuses in engine compartment and under dashboard engine check light comes on every 3000 miles for oil change reminder
Jul 23, 2012 | Cars & Trucks
Why check engine bulb indicates
There is error code stored in your cars computer.It has to be scanned to retrieve the codes stored in it.I suggest you to click the help links shown below :----Check Engine Light On car? http://schematicsdiagram.blogspot.com/2011/06/check-engine-light-on-car.html
--------------After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure? http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
------------After replacing throttle body the Check engine light starts blinking? http://technoanswers.blogspot.com/2012/01/after-replacing-throttle-body-check.html
-------------Check engine light with codes P2195 and P2197? http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
------------Car jerks while going uphill and Check engine light is ON? http://schematicsdiagram.blogspot.com/2011/12/car-jerks-while-going-uphill-and-check.html
-----------Vehicle smog test failed Due to NO MIL/check engine light? http://schematicsdiagram.blogspot.com/2011/12/vehicle-smog-test-failed-due-to-no.html
-----------This will help.Thanks.
Feb 07, 2012 | Cars & Trucks
Check engine light will not work.
open out the dash and replace the light behind
Apr 21, 2010 | 1996 Chrysler LHS
MY 2004 SUBARU FORESTER XT CRUISE LIGHT KEEPS FLASHING AND CHECK ENGINE LIGHT COMES ON AT THE SAME TIME
if te check engine light is on the cruise wont work it just flashes if you erase check engine light and cruise still flashes hit cruise button twice it will go out but if engine kicks the check engine light it will flash again you have to fix what ever it is that kicks check engine light or you just deal with it
Mar 17, 2010 | 2004 Subaru Forester
2002 Dodge Ram Gas Engine. Check Engine light
check your antifreez . that would make check engine light come on and no heat
Jul 05, 2009 | 2002 Dodge Ram Maxi
Car Audio & Video Logo
208 people viewed this question
Top Cherokee Car Audio & Video Experts
xxxxxx xxx
chargerhp
chargerhp
Are you a Cherokee Car Audio and Video Expert? Answer questions, earn points and help others
