Question about Goodman GMS90703BXA Heater
Goodman heating system -gmt1155b is not providing enough heat.
This heating system must have two heating stages. It is only heating ,and giving out warm air .It's not going into the higher heating stage. filter is clean ,returns are cleared. What can I do to get it hotter?
  • 1 more comment
  • Lou Barta May 11, 2010
    If you have two stages..second stage might not be hooked up. Check the main circuit board. Look for the thermostat terminals... Is there a W1 & a W2. if so, it is a two stage. Is there a wire connected to both terminals? if not, second stage is not connected. Do you have a two stage thermostat?
  • Dennis Boxerman May 11, 2010
    Are you sure this is a 2 stage heating system? If so, is the t'stat one that can be wired for this? Have you actually checked the temp of the air being blown out of the unit?
  • Barry Davis
    Barry Davis Nov 01, 2012
    our goodmans gas furnace will only run for 5 minutes then quits
    Sergeant:
    Champion:
  • 232 Answers
If you are using a single stage with just a W connection not a W1 and W2 then it may be wired to the W1 connection on the furnace contro board. in that case it will only run in first stage. the easiest thing you can do is run a small piece of wire between W1 and W2 on the furnace control board. if you dont have a W1 and W2 connection on the board then its not 2stage, if you have an extra wire at the stat you can get a 2stage stat and wire W1 and W2 individually.
Posted on Sep 18, 2009
Need help getting additional info for this system...
1-888-593-998eight. Goodman tech support. You should have your model# & serial# to both indoor/outdoor units if needed.
mobile.goodmanmfg.com/mobileapp/index.jsp#/mobileapp/asap/newPMainAction.jsp
This link gives a lot of info but not what you are looking for I believe. Most 2 stage equipment will have a Y1 and Y2 at the terminal block inside the air handler. And a two stage cool, two stage heat would work for yours, it appears to be a heat pump. Now at the outdoor unit, if it is 2 stage, you should also see Y1/Y2 terminals. As far as a filter media? Hard to say.
Jul 05, 2015 | Filter Heating & Cooling
Goodman gph1348m41ac unit is blowing cool air in heat mode with mid 30s ambient outdoor temp. I turn it off then on and will usually blow warm air but this cycle is becoming more repetitive. any expert...
A heat pump on the optimal heating day (about 50 degrees ambient) will only deliver approximately 85 degree air as compared to 125 degree air from a fossil fueled furnace. The colder the outdoor air is the less heat there is available to be transferred to the living space. At 30 degrees, the heat transfer capability is getting close to negligible meaning the run cycles will be approaching continuous and eventually as the heat pump along cannot maintain setpoint, the outdoor stat or stats will bring on auxilliary heat in the air handler.
If your ambient temp is below the 'balance point' of the heat pump, the house temp will drop a little lower and most times energize the heat strips through the outdoor t-stat. Your outdoor stat could be set too low for the heat pump to carry the structure all the way down to the balance point so when you turn it off and back on, the lower indoor temp automatically brings on the heat pump plus a heat strip or two, thus the warmer air. Second stage on the stat satisfies due to the heat strip, drops them out of the circuit and the heat pump is left running on first stage heat delivering the perceived cold air.
Your outdoor stat could also be not functioning correctly and not allowing the heaters to come on until the system is turned back on reestablishing the two stage call for heat.
Tons of possibilities and not enough room to list....
Jan 01, 2015 | Goodman Manufacturing Goodman GPH1348M41 4...
Goodman Model GMV950905DX-an electrical surge burned out the transformer which I replaced, also replaced the circuit board. The variable speed furnace will no longer kick into high speed and it will l
If I remember correctly, there are dip switches on that control board that can be set individually. It is possible that it is just a setup issue. The switch positions should be explained in the installation instructions. I know that some Goodman and Amana two stage furnaces can be controlled by a single stage thermostat, but the dip switches have to be set properly. If the switches are set correctly the furnace will run in low stage heat for approximately 5 minutes and if the thermostat hasn't satisfied yet, it will kick in to high stage heat. I hope this points you in the right direction!
Dec 16, 2014 | Goodman Manufacturing Goodman Gas Furnace...
Goodman a32-10
the fan is designed to come on with ist stage sequencer. you may have a bad heat strip and it is still heating
Feb 02, 2014 | Goodman Heating & Cooling
I am installing a heat pump, and i having 8 flashes at my green LED .
look at page 17 here is all the install instructions plus troubleshooting
x air conditioner/heat pump
operates at reduced
performance.
x Air conditioner/heat pump
operating at low stage when
expected to operate at high
stage.
x Integrated control module
diagnostic/status LED's display
the indicated code
http://www.alpinehomeair.com/related/IO-348K%208.2013.pdf
Oct 06, 2013 | Goodman Manufacturing Goodman DSZC160601...
Outside unit not running, inside unit is running, but blowin heat. Goodman unit MODEL CK-J60-1
eletrick furnace? then it is a stuck heat sequencer(relay) the first stage heat sequencer also runs the fan in heating
Jun 26, 2010 | Goodman CKL60AR60 Air Conditioner
No heat, got great a/c....
W1 and W2 are the differences from the single stage to the two stage. Im thinking its your thermostat is not programed for 1 heat / 1 cool. You probably had 2 heat / 1 cool before.
Oct 17, 2009 | Goodman Heating & Cooling
Can you bypass piggyback system if you want to just use heatpump. John
I'm assuuming you are talking about your furnace or 2nd. stage heat, when you say piggyback system. Yes you can go to your thermostat or furnace and disconnect just the 2nd. stage heat wire(see furnace wiring diagram), this will not allow the heat to come on in the furnace but it will still allow the indoor blower to run and the heat pump.
Apr 20, 2009 | Goodman CLQ36AR49 Air Conditioner
MY HEAT PUMP SYSTEM WILL NOT WORK IN EMERGENCY MODE
the thermostat sub base has a place to connect a wire usually white to energize the heat strips when you push the stat way hotter than the house temp. that is why the strips come on in normal heat. it also has a terminal that is only energized in emergency heat and it also should have a wire connected to it so that terminal can supply power to the strips when the stat is switched into emerg heat . you can identify the terminal from the wiring diagram and if need be jumper w2 wire over to the aux terminal and it will work. they both go back into the airhandler and power the same strips. w2..................................................................................................w2 in airhandler to strips or w2...jumper to aux......................................................................................................................w2 in airhandler to strips.
Nov 10, 2008 | Amana PTH123B25AJ Heat Pump Air...
Goodman GMS90703BXA Heater Logo
171 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
