Dead laptop laptop just died , very dim power light on but nothing else, funny thing , when I take out broadcom wi-fi card , dim light goes out
  • RescueTechLA
    RescueTechLA May 11, 2010
    Can you still see the screen very very faintly, try using a flashlight maybe to see if you can see your desktops or anything at all. If you could provide a few more details it would help too.
    Novelist:
  • 148 Answers
take out the battery of the laptop and try starting it on the AC adapter,
if it doesn't work, if your friend has the sam ac adapter try starting your system with a different Ac adapter, if nothing of this works
call your laptops technical support
Further Queries are welcome
If you think my solution was helpfull please do rate me
Posted on Feb 21, 2009
Where is my WiFi Card located on a Gateway M305crv laptop? I purchased a BroadCom BCM94306 Mini Pci Wireless WLAN Wifi Card as the specifications indicated. Now I don't know the location of the WiFi...
Hard to explain so video shows where it it most likely located on bottom of laptop
see this video to see in first part of video 5 min 18 seconds where the wi fi card plastic cover it located on bottom of laptop
https://www.youtube.com/watch?v=oFwzdP216Cg&list=PLoQ4NWSN36fECZjaAGHCflBAPBAOm5gAL
I would recommend using ESD precautions that are not observed in the video link above
https://www.youtube.com/watch?v=R-I8XGdrD5w
ALSO TAKE out POWER CORD and LAPTOP BATTERY ! Before attempting fitting
Aug 11, 2015 | Gateway Computers & Internet
I cant connect my dell latitude d531 to the internet
Press the button just to the left of the power button (when mine turns on the bluetooth light appears just below the screen on the right side). See if it works now. If not, reboot, press the F2 key during startup (keep tapping until the message in the upper right goes to "Preparing to enter setup") to go into Setup. Go to the bottom of the list on the left side to Wireless. Hit enter to open the list, go down to Internal Wi-Fi and make sure it is enabled on the right side of the screen. Also, check the last setting and set LAN/Wi-Fi Auto Switch to Off. You might also have a bad wireless card or a bad driver. If nothing works then re-post as possible driver problem.
Apr 26, 2010 | Dell Latitude D531 Laptop Computer PC...
I have a compaq presario F756nr with an Atheros wireless wi-fi card in it. Can I replace the wi-fi card with a Broadcom 802.11 b/g wireless LAN card?
no you cannot replace the built-in wi-fi card...
if you try to change the drivers for atheros wi-fi to Broadcam driver, your wi-fi card will not function anymore.... but you can always install another WI-FI card in your laptop... you can buy a USB Adapter or a Cardbus(PCMCIA) adapter for this purpose...if you want your wi-fi signal strenth and range to be higher, you can opt to buy an adapter which comes under N standard....N standard wi-fi adapters are capable of connecting at a speed of more than 300mbps(practically) to any N standard device like router....
Mar 29, 2010 | HP Compaq Presario F756NR Notebook
My friend has a dell latitude c400 which will connect to internet via earthnet, has a built in wireless but how do he turn this function on, what short key or anything else is it, pls helllpp
Go to Network conections and enable the wireless device. OR, you may need to open up the wi-fi door and check the model# on the wi-fi card, and type in the model# followed by 'drivers' in a Google search to acquie the drivers, too
Sep 24, 2009 | Dell Latitude C400 Notebook
Broadcom 4321AG 802.11a/b/g/draft-n Wi-Fi-Adapter datasheet
that depends on the network traffic to and from your computer..but it will never be 0 once connected..
Jan 14, 2009 | Broadcom BCM94306MP - IEEE 802.11b/g...
Gateway PC crashing when connecting to Wi-FI
if i was you i would load up a version of win xp on another hard drive inserted into your laptop, load the drivers for the laptop including wi fi drivers then see if ok. if not you can be sure its a faulty wi fi card in your laptop,you need to disable internal wi fi card remove,replace it.but first try borrow a pcmcia wi fi card just to check if everythings ok
Dec 06, 2008 | Gateway MX6438 Notebook
WiFi driver for Acer Laptop 4720 for Linux (Fedora version 8) free download
Try this link and see if it helps you locate the driver you need for linux. These are the Broadcom drivers, http://zh-tw.broadcom.com/support/ethernet_nic/netlink.php
Sep 11, 2008 | Acer Aspire 5100 Notebook
How install wi-fi drive in compaq tu 795 model
The Vista drivers can be found here
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=3739763#
please note that there are 3 possible wireless network cards in this laptop, I sugest you download all, and try each in the following order
Intel
Broadcom
Atheros
remember to uninstall each driver if it is not correct
If you are runing XP, you will need to try and locate the relevant 3 XP drivers from the 3 manufactures sites EG: Intel
Aug 27, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
132 people viewed this question
David Payne
David Payne
