Question about Rheem Water Heaters
Water heater is turned on but no .what to do
Water heater is hooked up to electricity bur not heating
  • 350 Answers
Dear martimccammo, Friday 2-20-2009 11:07pm EST (USA)
Has it ever worked?
Is it new?
How old is it?
What exactly happened?
jack
Posted on Feb 21, 2009
Hooked up water to city water and there dosn't appear there is any water in tank
Should be a cold water valve nearby on fill line. Turn water on & fill BEFORE applying electrical power or you will burn out heating elements in seconds!
Feb 14, 2017 | Water Water Heaters
We're is the fuse located for the electric water heater I have hot water on gas but the electric heater just stopped when I'm plugged in
It is not fused, they don't use fuses and haven't for decades, it is hooked into the house current at the breaker box for the house.
Jul 21, 2016 | Water Water Heaters
DOES WATER IN GO ON TOP OR BOTTOM OF HEATER
1) Low-boy water heater, cold water connects to lower inlet pipe and hot to upper outlet pipe.
Cold enters bottom of heater and then hot water rises to top where it leaves tank.
http://waterheatertimer.org/images/20-gal-heater.jpg
2) With larger water heaters both hot and cold connections are on top of tank, but the cold water goes to the bottom through the dip tube.
http://waterheatertimer.org/Water-heater-dip-tube.html
If pipes are reversed, the water heater will not work.
Jun 10, 2011 | Reliance & Lowboy& Electric Water Heater
I just installed a new electric water heater with dual high limit elements.I hooked up the red and black wire, just like the old one and set the limits to 125 and turned on breaker. we waited about 6hrs...
Most water heaters heat the water on top first. This is because the warm water will rise to the top and the hot water is drawn off the top. When the upper thermostat turns the top element off then the bottom one comes on. It makes it sound like there is a problem with the top element. Disconnect electric, and read the resistance on the element terminal to terminal. If it shows open the you have a bad element. Did you make sure the heater was completely full before turning the electric? You must run the hot faucets to remove all the air from the top of the tank before turning on the electric. Elements will burn out quickly if out of the water.
Nov 09, 2010 | RELIANCE ELECTRIC WATER HEATER
The water seems to be hotter than usual and my electric bill has increased by $100.00
There may be sediment buildup in the tank bottom, which can cause this. Shut off the electricity to the unit, drain off some water from a faucet that should be at the bottom outside of the tank and see what comes out, if a lot of dirty water and sediment comes out that may be it. Let it flush until clear water comes out. You will probably have to hook a garden hose on the faucet to get the water to a drain or outdoors.
Be sure to shut off the power to the heater first!
Then let the heater fill back up with water and turn on the power and wait for it heat up.
Jun 08, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
New electric water heater doesn't seem to be working.
Take off the two grey covers, being really careful because you are dealing with live electricity, and make sure that the adjustments on the temp is set high enough to even turn on. sometimes they come from the factory that is not set high enough to even heat the water.
Please rate
May 31, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
No hot water from brand new heater
check your thermostat's,be sure they are turned up,tighten all (check),elect' connection's.
Apr 27, 2010 | Reliance & 50gal Electric Water Heater
Burnt element on water heater
It would be a good idea.If you don't you have water all over you and the heater.Turn water off and open the drain valve at bottom of heater.I would hook a water hose and run outside.when the water start running open the pop off valve ,it will run faster.
Mar 23, 2009 | General Electric GE SmartWater Household...
Whirlpool electric smart water heater not heating all the time
DO YOU HAVE A MANUAL FOR AN 80 GALLON
ENERGY SMART ELECTRIC WATER HEATER?
THE MODEL # IS EE3Z80HD055V
I HOOKED EVERYTHING UP, THE GREEN LIGHT IS ON BUT I DONT HAVE HOT WATER YET.
Mar 04, 2009 | Water Heaters
Water Heaters Logo
32 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
