Question about Amana ABB1927DE Bottom Freezer Refrigerator
Fischer Paykel fridge freezes then stops
My Fischer Paykel c450 (Fridge only model) has an issue. The top section freezes causing the fan to jam. If I defrast the fridge and water drains out, it will work straight away , lasting about 2 days before re freezing
The themostat seems to be initially working and temp gets down quickly to 4 or so degrees.
If its the thermosta control is it easy to replace?
  • Catherine Mendes Feb 28, 2009
    I'm not sure if it has defrost heaters. It seems to be ok for a few days once defrosted and you can hear the thermostat click in / out. it only seem to last a few days before it re ices
  • Len West
    Len West May 11, 2010
    What setting are you using?
    Problem Solver:
  • 19 Answers
Sounds more like a defrost problem, check your defrost timer, defrost heaters.
Posted on Feb 21, 2009
Everything on top shelf of fridge freezes even on lowest temperature
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Nov 25, 2013 | Hotpoint Refrigerators
I have a fischer pukle fridge making a whisling sound after a thunder storm
It maybe just coincidental that the noise appeared after the storm. However, if carbon deposits caused by an electric ark have created interference to something like the fan motor bearings. One would that any associated electronic device would not function either, if fitted.
Nov 18, 2011 | Fisher and Paykel Refrigerators
Fridge is freezing everything, i want the process of testing the theromostat and if its not that I beleive it is low gas, it is not icing up ect. fisher and paykel fridge model c370. Theromstat has 5 wires...
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Take care.....
May 07, 2011 | Fisher and Paykel Fisher&Paykel E522...
The Fridge Section is freezing even though I have the frisge settings on the lowest setting! Jeff Malley 0402 004405 Rye Vic.
I have this same issue on a C410B, also located in Rye .
I think its a thermostat issue, unless yours is freezing only on the bottom of the fridge (which could be a fan circullation issue)
Jan 01, 2011 | Fisher and Paykel Active Smart E522B...
THE FRIDGE SECTION IS FREEZING , AFTER WE HAD THE FREEZER REPAIRED
more than likey a provisions compartment fan ,(fridge compartment) symptoms include temprature stratifcation( where product freezes in lower part of refrigerator eg: crisper draws and top shelf warmer....
fan may appear to be functioning but broken wire may cause intermittent operation ..you can test these fans remove fan ...and test with square 9 volt battery or 12volt d.c supply....i hope this could be of use
ozzie fridge tech...;)
May 21, 2010 | Fisher and Paykel Active Smart E522B...
Bottom of fridge section freezing, rest fine.
maybe fridge fan not working when door is closed could also be iced up air ducts between fridge and freezer
Oct 09, 2009 | Fisher Refrigerators
Uneven cooling in fridge and annooying alarm every 10 hours!
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 28, 2009 | Fisher and Paykel Active Smart® E522BR...
Maytag msd2456dew not cooling / not freezing after noisy fan
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Sham
Feb 15, 2009 | Maytag Refrigerators
Top of fridge warm but bottom freezer working ok
Dear customer,
Please perform the following checks
Please rate this,. Thanks for using FIXYA.
Dec 16, 2008 | Fisher and Paykel Fisher Paykel 21768 -...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
226 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
