Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer is dripping water (on inside) when it is just sitting and not being used
  • Whirlpool Master
  • 2,651 Answers
Sounds as if yo uhavea faulty inlet water valve. you ned to replcethe vavle, in mean time you can turn off water valves inbetween washes!
Posted on Feb 21, 2009
Water dripping onto passenger side floor from the inside passenger assist handle.
Does your car have a sun (or moon) roof? A leak in a sunroof will sometimes follow the roof over to the door post and down to the floor were the water will accumulate. This can be hard to find sometimes but having one person spraying water on the roof while a second one checks the inside of the vehicle you may be able to pinpoint the leak.
Hope this helps.
Jan 05, 2015 | 2003 Chrysler Town & Country
After washer has stopped, it contunes to drip inside the tube
Start the washer in a normal cycle, once it starts to fill, unplug the unit from the wall. If the water stops completely its not a water valve issue. If it still drips, replace the water valve to the washer. Good Luck
Jul 12, 2014 | Maytag Atlantis MAV6000 Top Load Washer
Water dripping inside tub of washer when washer not in use
Your water inlet valve is not shutting off completely ,should be replaced if it fails completely it will flood and not stop seen it happen more then once
Feb 18, 2013 | Whirlpool Cabrio WTW5500XW Top Loading...
When the washer sits idle, water will drip in the tub from the top rim at about a drop every 3 seconds. it is a maytag laundry washer #mav4755aww
Your water inlet valve on the back where the water hose connects to the washer is not sealing completely when it's off. It get sediment in it over time and causes this especially if you use well water.You may can stop it by cleaning the valve or replace it. There is one valve for the hot and cold together. There is a screen filter in the water hose where it connects to the water supply.
Jan 17, 2011 | Maytag Washing Machines
Water drips inside tub when washer is not in use. Can't tell exactly where it's coming from or how to get inside the back.
Water valve needs replacing. Determine which one by turning off either hot or cold at the wall and watching to see if drip stops.
Alternatively, just turn off the wall taps each time you finish washing.
Mar 23, 2010 | Estate Washing Machines
Whirpool Ultimate Care II washer - drips
Your water inlet valve is leaking through. Turn off the water. Remove the hoses from the washer. Clean the sediment screens in the water valve and replace the hose.
If that does not solve the leak through problem,the water inlet valve will have to be replaced.
Use the attached video to show how to access the inside of the washer in the event the water valve needs replacing.
Nov 08, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Leaks badly
Most dish washers do not seal at the bottom, the door lip just sits
in front of the tub lip and does not make a real tight seal like a refrigerator door, so unless water is spraying out the top and sides of the door,I would assume that it is either overflowing,or you are using the wrong detergent and it is just foaming to much inside the washer and going over the lip and dripping on the floor. Once the suds stop getting agitated then turn back to water and don't look like suds.
So if you watch the washer during the cycle and the water s only coming from the bottom it is the water level switch inside on right
in the front,looks like a mushroom, once the washer reaches a certain level of water this switch floats up and shuts off the water to stop it from filling anymore. If this seems to be the case just remove the front bottom kick panel and you should be able to see the switch, watch it when the washer is filling,you can also push up on the little arm and the water should shut off. Post back with any questions.
Apr 16, 2009 | LG LDF6810ST Stainless Steel Built-in...
When washer finishes there is a dripping of water inside unit
What has happened is you have sand in your water valve from your water. This pluggs the water valve and also sticks it open so when the water valve shuts of there is still a small trickle of water coming through the washer. Replace the water and it will fix the problem (no way of cleaning the inside of the valve.) Replace water valve.
Nov 24, 2008 | Maytag Washing Machines
Kenmore front load washer
pull despencer out ck if its dripping inside washer has a bad inlet water valve
Mar 01, 2008 | Kenmore 42822 Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
73 people viewed this question
Dan Webster
Dan Webster
Sal De
