Good Afternoon David, thank you for your post!
From what you have described your Frigidaire range your Frigidaire oven shuts off and display remains the same. This could be a faulty control panel or wiring harness. In order to diagnose which component could be the problem you would need to disassemble the range and test each electrical part. I would recommend this be completed by a technician for proper repairs. This will help you avoid any unnecessary part purchases. -Matt
I appreciate your inquiry, David!
From the information you have provided your Frigidaire microwave shuts off and then will factory restart. It sounds like a possible problem with your control panel or a faulty wiring harness. I would recommend seeking assistance from a professional. They would need to properly disassemble your microwave and test each electrical component to pinpoint the problem within it. The technician has the appropriate tools needed to complete the repair without causing personal injury or any future issues with the microwave. Best of luck! -Matt
Thank you for your inquiry, friend!
From the information you have provided your Frigidaire stove is not unlocking and you have shut it off at the breaker and pressed clear. You have performed the proper troubleshooting regarding your stove and it appears that you could have a possible problem with the door latch or control panel. I would recommend having a professional technician come out and complete a diagnosis and repair on your stove. I hope this information is helpful. -Matt
Hello kdccampbell2 - Does "LOC" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. Press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Do the maintop burners work? Confirm the shut-off valve on the gas pressure regulator is in the "ON" position. This valve shuts off gas to the oven (typically located on the back left-hand side of the range). I do not suggest re-lighting the unit, as this may cause harm to you and possible damage to the appliance. Contact a professional to move forward accurately and to assist with the repairs.
Hello Larry D Harris - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Do the maintop burners work? Granting that it does, you can try confirming that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. If after the basic troubleshooting, you continue to experience the issue I would suggest contacting a certified technician to assist in the full diagnosis and repair of your range.
Hi - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Do the maintop burners work? Granting that it does, you can try confirming that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. If after the basic troubleshooting, you continue to experience the issue I would suggest contacting a certified technician to assist in the full diagnosis and repair of your range.
