Question about Bowflex Treadclimber
We just purchased a Bowflex Treadclimber 1000. After 10 seconds it stops and flashes E1. Does anyone know anything about this?
  • 1 more comment
  • meganlance Mar 01, 2009
    My niece just spilled a chocolate malt on the treads. As soon as we noticed we stopped it, unplugged it, took the sides and back plastic pieces off, cleaned the ice cream, and let it dry a bit. Now it has been a day, runs for about 10 seconds and get "E1" error code. We know there has to be a simple solution, what needs cleaned or replaced, does the computer memory simply store that something happened, and not let you use the machine till you spend $300 for a repairman to come out and push a reset button hidden inside...lol. Any help would be very appreciative. I'm not afraid to fix myself. contessantony@hotmail.com
  • Anonymous Apr 21, 2009
    same issue here...can't get past the E1 error code and nothing is listed in the manual
  • Anonymous May 06, 2009
    We have the same problem, though nothing even spilled on our machine. It will run for about 2-3 minutes and then stop and indicate the E1 error. Help!
Putting the drive sensor wire back in the correct place workedWe just purchased a Bowflex Treadclimber 1000. - getattachment.aspx&hm__qs=file%3d3d2f2ee0-2668-46ea-b32c-db049d56cb37.jpg%26ct%3daw1hz2uvanblzw_3d_3d%26name%3daw1hz2uwmdiuanbn%26inline%3d1%26rfc%3d0%26empty%3dfalse%26imgsrc%3dcid%253aimage002.jpg%254001c99c08.13bd6320&oneredir=1&ip=10.12.128.8&d=d6608&mf=0&a=01_0b590aaade5e800af268d347750ab151eca93264be20cd9ce2166e583b18cfe9
Posted on Mar 03, 2009
Tread climber starts up and shuts down in a few seconds. Starts clicking
Bowflex Treadclimber Shuts down - Questions - Fixya
www.fixya.com > Forum > Treadmills > Bowflex > Bowflex Treadclimber
Bowflex Treadclimber, shuts down related issues. ... After a few times of shutting down due to the heat. Ad ... It shuts down about 60 seconds after it starts.
Customer Reviews: Bowflex TC3000 Treadclimber
www.amazon.com/Bowflex...Treadclimber/.../B000B...
Amazon.com, Inc.The second time I used it I slowed down the speed and worked on getting the ... After researching the TreadClimber for over a year (the cost was a big factor .... We were never able to make the treadles go up and down more that a few inches. ..... a great workout However it continually shut offs while working out and Bowflex ...
Comments for Bowflex TreadClimber Problems
www.treadmilltalk.com/bowflex-treadclimber-user-comments-comments....
Oct 30, 2013 - NOTE: My comment about Bowflex Treadclimbers is also one I left in another area. ... seems like no one sprung the extra few bucks to pay for someone to put the ... In my case , after the initial startup, the machine stops EVERY time at ...nearly spine snapping shutdown at exactly 32 minutes after starting. 5.
[PDF]Bowflex® TreadClimber® 1000, 3000 & 5000 - Nautilus
download.dfxi.com/.../SM/Bowflex/BFX_TC135_SM_RevA_web.pdf
Jan 27, 2016 | Bowflex TreadClimber TC10
MY TREAD CLIMBER STARTS THEN STOPS AND FLASHES E1 ACROSS THE SCREEN
This is probably a faulty speed sensor or the speed sensor is not plugged in properly. Its also possibly a faulty motor control board or lower board. The error codes will differ between makes and models but could be e1.
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8
hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
Watch this videos and tip.
You must concluded if the inclination motor is faulty or Main Motor Controller Board is faulty.
Oct 18, 2011 | Bowflex TC1000 Treadclimber
Our TC 1000 stopped. We get the Error Code E1 when we try to turn it on. There is no sound or any movement. I don't know where to start. Help.
hi
ur treadmills speed sensor have some problem. pullout it clean it and then refix it. also check its white connector , is its connection is proper or not. if the sensor found faulty replace it.
ok
Dec 20, 2010 | Bowflex TC1000 Treadclimber
My bowflex treadclimber goes slow/fast/slow again and stops. It then shows an E1 on the display. What can I do to fix this? I have no directions for trouble shooting. Also, should I be able to speed...
The speed sensor is not connected correctly. There should be a jumper wire that runs from the speed sensor over to a harness by the control board on the other side of the machine. There may be a second jumper wire connected to nothing, only used in the 3000/5000 models. There is also a wire that comes from inside the treadles that isn't used on the 1000. The current assembly manual available from bowflex online seems to explain it better.
Oct 26, 2009 | Bowflex TC1000 Treadclimber
Bowflex tc 1000 treadclimber
TC1000 from Bowflex, works okay for 15 mins then the speed surges ahead and stops dead with error E1
Jun 28, 2009 | Bowflex TC1000 Treadclimber
Error Code E1
I had the same error message E1 at 10 seconds according to the LCD display on an older Treadclimber TC1000. I called Bowflex 1-800-792-6784 and first thing they told me was to check the drive sensor on the back left corner of machine. It is two wires connected by 2 white connectors that snap together. The end of the sensor has a rubber cap that is supposed to be approximately 1/8 inch from the drive pulley. The rubber cap plugs into a small hole within the "firewall" of the drive pulley, but the end of the cap does not actually touch anything. They can email you a picture of it. If it ever gets knocked loose, the machine will register this e1 error, in some cases- hope this helps.getattachment.aspx&hm__qs=file%3d3d2f2ee0-2668-46ea-b32c-db049d56cb37.jpg%26ct%3daw1hz2uvanblzw_3d_3d%26name%3daw1hz2uwmdiuanbn%26inline%3d1%26rfc%3d0%26empty%3dfalse%26imgsrc%3dcid%253aimage002.jpg%254001c99c08.13bd6320&oneredir=1&ip=10.12.128.8&d=d6608&mf=0&a=01_0b590aaade5e800af268d347750ab151eca93264be20cd9ce2166e583b18cfe9
Jan 24, 2009 | Bowflex Treadclimber
Bowflex Treadclimber Logo
627 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Glenn Mayer
Glenn Mayer
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
