Question about Bosch Nexxt 300 Series WFMC2201UC
I have a Bosch washing manchine nexxt 300 series, when i push the on button it will not come on
The lights r on but when i push the button to start the washing it will not start. It was working yesterday March 3, 2013.
  • 53 Answers
Check door switch. If OK then your probably looking at a motor control board problem. Ck connections on it. It is located in the back right corner of the machine.To get to it take the back off and it will be on the bottom left.
Posted on Mar 04, 2013
SOURCE:
  • 157 Answers
SOURCE: HELLO I have a Bosch Nexxt 300 series and I
under loaded fill it up
Posted on Jun 30, 2009
  • 228 Answers
SOURCE: Hello! My Bosch Nexxt series 300 washing machine
e 13 is a door lock error if you are lucky you may have a manual release check where filter is for a red pull release this mechanically activates the door to retrieve trapped washing,if not lock will need replacing engineer visit unfortunately.
Posted on Aug 05, 2009
  • 10 Answers
SOURCE: My brand new Bosch is not draining and is showing E:13 error code
Put the washer on cold and run "TWO" cycles. There is too much soap or fabric softner.
Posted on Nov 27, 2009
barkencoa
  • 3463 Answers
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Posted on Jan 11, 2010
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
  • 1075 Answers
SOURCE: Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
Posted on Jun 29, 2010
My dishwasher won't start when i push the button, why ?
call a repairman .most likely the door lock switch has failed onit .
Sep 24, 2015 | Dishwashers
Kenmore 665 Dishwasher
Sound like you have a bad control console, which will need to be replaced.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Apr 08, 2012 | Kenmore 13742 / 13744 / 13749 Built-in...
The delay start light on my washer is on and I do not want to delay start. I have pushed the cancel button twice like instructions say and once I hit start, the delay start light is on and machine is...
First I made sure the detergent dispenser door was closed. That did not work. Then i made sure that the dispenser was clean, by running water thru it. That did not work,. Then I turned the dial to hand wash and pushed the start button. That worked. Delay light did not turn on. Then i turned the setting to the proper wash cycle and pushed the start button. Clothes are being washed now.
Nov 23, 2010 | Frigidaire FTF2140FS Front Load Washer /...
I washed my V-Strom 650 yesterday and now it won't start. Lights, gauges react to key, fuses all seem fine, however, I get no response from start button. Lights dim when I push start button and that's...
It's probably just the the clutch ignition wiring clip located directly underneath the clutch lever. It seems to come unplugged fairly easily. I had the exact same problem and this was the quick fix.
May 04, 2010 | 2006 Suzuki DL 650 V-Strom
I purchased my itrip in march 2009. Has been
try leving it and torn it on hand he shold light up becuse mine did that and he is working now
Aug 25, 2009 | Griffin Technology iTrip® FM Transmitter...
Washer won't run , push start button just beeps
in order to determine what is the cause of your problem , please provide the error codes an model number so we can figure out what is wrong with it, has anyone set anything heavy on top of the machine if is a top load machine, first guess if you have power to the machine would be look into the lid swtich an go from there....
May 28, 2009 | Bosch Washing Machines
Duet washer deliv yesterday start button won't work.
delivered yesterday??? call back the dealer and have them send out a repairman/ or replace the unit you didnt pay for a brand new unit to be reapired
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag neptune,shuts down within 10 seconds after start button is pushed
If it has worked for a year and your able to choose different cycles with the same result. It seems to functions with one common element failing. If the control unit cant detect how full the machine is with water it will shut down. Sounds like a water problem steming from your pressure switch. Not sure which model you have but usually it will sit on the water pump or under the console with a clear hose if under the console. If so a quick test of attaching an ohm meter set on continuity then blowing lightly to see if under pressure the switch reacts by closing if it doesnt then the switch is bad.
Sep 16, 2008 | Washing Machines
Just installed, will not work
Did you remove the shipping bolt in the back of the unit??
Jan 24, 2008 | Frigidaire Affinity ATF7000EG
Bosch Nexxt 300 Series WFMC2201UC Logo
269 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
