The only fuse that this machine has is locate with the lid switch. Take the screws out of the top of the console and with the machine unplugged, pull the front of the console loose. If fuse is bad, check your lid switch and connections with an ohm meter to make sure they are ok
If this does not work on any cycle then make sure you have electricity at your outlet as there is no fuse for this unit. If you have power but it will not work in any cycle then you most likely need a new timer. If the unit will fill and wash but not spin or drain then you most likely need a lid switch.
The lid switch or the lid switch fuse may be bad. Open the control console to check the switch and fuse located in the center of the machine,behind the control panel. Also check the belts underneath to make sure they are not broken or stretched.
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.Here is the part you need.
HI. thanks for the question. you have a blown fuse ,inside the washer. remove the front panel. on the left ,you will find a small glass fuse .check that. if its failed you will be able to see, that the small metal strip inside the fuse is broken , if so replace the fuse. thanks the appliance doc . please rate my answer.
