Question about Microsoft Zune JS8-00001 Digital Media Player
Zune will not work
Zune sign shows up, makes a clicking sounds then flashes a big battery and says connect support
  • duttyclan Mar 04, 2009
    first it froze.. then unable to play mucis but still can navigate through menu.. then froze...said contact support.. and now clicking sound is on while on the zune start up screen.... dead?
  • cubsmarks Mar 06, 2009
    I have the same problem. Only solution that customer support gave me was to purchase a new one at 159.00 dollars.
  • 38 Answers
Your hard drive is frakked. For all 3 of ya.
Try these steps (cubsmarks, did Support get you to try these at all?).
If your warranty is valid, y'all can get it replaced. But, the 30's been around since the beginning, so... {{shrug}}
Posted on Mar 08, 2009
My zune will when plugged in do the little loading screen get the bar to the end and then make a clicking sound then start over and if i try to start it up it will either show that the battery needs to be...
Hi your HD is going bad. You can try reloading the firmware but it that does not work or cant be done you will need to replace the HD. Hope this helps
If you need more help, parts or repair services you can go to my repair service web page at and find info to contact me if needed. thanks
Dec 12, 2010 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune will not turn on
1. If the Zune device is not connected to a power source, set the Hold switch to unlocked. Then, press and hold the Play/Pause button to turn off the device. • If this does not work, restart the device. To restart the device, set the Hold switch to the unlocked position, and then press and hold the Back button zune_button_back.gif as you press the top of the Zune Pad. When the device begins to reset, you can release the buttons. 2. If the Zune device is connected to a power source, it is operating correctly. You cannot manually turn off the Zune device. Note Depending on how you configured your backlight setting, the backlight for the Zune device may automatically turn off in this situation. To access the backlight options, select display on the settings menu, and then press the center of the Zune pad. To adjust the setting, select backlight, and then press the center of the Zune pad.
Mar 21, 2008 | Audio Players & Recorders
Zune 30gb wont start
Update the firmware in that zune and you should be doing great if not microsoft has recalled some of there 30 GB versions due to the latest zune error.
Apr 23, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
I have Zune 30GB mp3 player. When I try to charge it using computer or wall charger, it tries to turn on and makes some clicking sound and turns off again. It does it repeatedly but can not charge it.
the zune does this if the battery doesn't work (needs a charged battery to power on). battery is either defective or disconnected. there is a zune repair guide that shows you how to fix it
Apr 22, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune just stopped working
run the battery completey dead or you could possibly reset the device to factory default...
Try this....
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
Mar 22, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
I can't turn on my zune
Try this.
Lot's of steps, but one might just work for you.
Feb 25, 2009 | Microsoft Zune JS8-00001 Digital Media...
Unresponsive (and dead battery) zune o' saddness
Power sources that are supported loadTOCNode(2, 'moreinformation'); To charge the battery in your Zune device, you must connect the Zune device to one of the following supported power sources:
  • A computer’s USB port that you can connect to by using a Zune Sync Cable.
  • A Zune AC Adapter that you can connect to by using a Zune Sync Cable. Note The Zune AC Adapter is sold separately.
  • A Zune Car Charger or a Zune FM Transmitter/Charger. Note These items are sold separately.
  • An Xbox 360 console's USB port that you can connect to by using a Zune Sync Cable.
  • A “Designed for Zune” mobile battery pack
Nov 09, 2008 | Microsoft Zune JS8-00001 Digital Media...
30GB Zune turns off
i had the same problem
try this it worked for me conet you zune to a charger externaly ie not on the computer
through the mains plug adapter it works fine but when i unplug it go back to flashing on and of
let me know how you get on
Oct 22, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
First time chargin Zune 30GB Brown
I had the same problem (frozen after first time trying to charge.) I found the solution on another site. I just unplugged the device and let the battery drain completely, then plugged it back in (rear usb port) and voila, it works, that simple.
Nov 30, 2007 | Microsoft Zune JS8-00001 Digital Media...
My zune wont turn on
I turned on my Zune and the screen froze so I turned it off but it would not turn back on.
I went online and read somewhere that if the screen freezes then you should press up and back and wait for the zune insignia to come on. Well my zune was not just frozen it would not go on but I tried the up and back thing and it worked. it took about 9-13 seconds but it worked so give it a chance and if that doesn't work try charging it overnight. Hope that helps :D
Nov 12, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft Zune JS8-00001 Digital Media Player Logo
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
