Question about LG Bottom Freezer Refrigerator w/ Swing Freezer Door 22 Cu. Ft. - LRBN22514
Refrigerator LG Model GR-T452G freezer works but fridge doesnt due to airflow between freezer to fridge blocking up with ice. I am having to pour boiling water down the back of the freezer to get the fridge to work each day. I assume it is a problem with the cyclic defrost, but I have no idea how to reapir or at least identify the problem. Can anyone help?
  • 1 more comment
  • Anonymous Mar 18, 2014
    Freezer works but the refrigerators not getting cold
  • Anonymous Mar 21, 2014
    Lamp & Fal Not Work
  • Anonymous Mar 22, 2014
    freezer works but not the fridge
    Problem Solver:
  • 19 Answers
Locate your defrost timer, they are either in the buttom front of the refrigerator, in back of the refrigerator, or inside compartment behind the plastic covers. On the defrost timer there is a slot were it can be turned using a screwdriver, or there is a round window were you can see it running.when you turn this dial and it clicks, you should now go into defrost. with all the ice build up in your evaporator you should hear the ice cracking indicating that the heaters are working, if not you might have open defrost heaters.
Posted on Feb 21, 2009
  • 150 Answers
The best way I know is to totally defrost it.Unplug it clean it out,put pans of hot water in it to speed up the process,leave the doors open.When you star it back up set at 4 or 5 and keep an eye on it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
LG french door fridge - makes hideous noise - loose bearings? - whenever fan is running, which is several times an hour. Any idea what is causing it? Husband tried to grease the fan. It's really...
A broken fan blade can cause a noisy motor. or a buildup of ice can cause some noise. If thes aren't the case you will need to have the fan motor replaced.
Jan 04, 2011 | LG LRFD25850 French Door Refrigerator
We have a lg gr-s592gt and we noticed the frezer is working fine but the fridge wasnt cold. i noticed that the two fans that controller the temp in the fridge arnt working but everything seems fine , this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Ice build up and stops the fans...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | Refrigerators
Refrigerator is not cold (50);freezer is working; vents not blocked. What can I do? Fan is working, & compressor does kick on.
Nine out of ten times it turns out to be a defrost issue. What most people dont understand is the refrigerator gets its cool air from the freezer. If the evaporator coil in the freezer becomes a block of ice then the airflow from freezer to fridge section is blocked. The block of ice along with already frozen foods in the freezer compartment help to keep those foods frozen. Therefore you assume the freezer section is fine. However, the lack of cool airflow to the fridge side quickly turns that 38 degree air into 50 degree air. You could try unplugging the fridge and leaving doors open for 24 hours, this will thatw the evap coil. Plug it back in after the 24 hours, and within 12-24 hrs everything should be cool. If the fridge continutes to cool for about 3-6 days and then fails again, you certainly have a defrost problem. This is long winded, but hope it helps
Mar 01, 2010 | Refrigerators
My freezer is working perfectly but the fridge is not
The channel in the back were the cool air comes down from the freezer to the fridge may be iced up. Try defrosting the fridge/freezer for much longer than usual, all day if necessary.
Aug 30, 2009 | LG LRTP1231W Top Freezer Refrigerator
Freezeris -1 fridge 47 degreeze F
I'd check all the venting make sure there is no plastic bags blocking the vents in the freezer and or fridge compartments. for some reason there doesnt seem to be proper airflow.find the fride door switch and hold it in the closed position with the door open and feel for airflow around the fridge vents. If theres none or very lttle you might have a defrost problem. Check for frost on the back wall inside the freezer.
May 20, 2009 | LG LFX25960ST Stainless Steel French Door...
LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Mar 02, 2009 | LG LFD25860
Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Feb 24, 2009 | Hotpoint Freezers
Kenmore 795.7731 Fridge warm;freezer cold - Error er dH
I faced the same problem for Kenmore elite Trio Model # 795.77543600 bottom freezer refrigerator. The issue as pointed out by Medeer on fixya.com, turned out to be the part called component assembly, part number 6615JB2005H. I got this replaced yesterday but for 4 hours I did not notice any cooling... so I thought it did not work.... but then in the morning I notice that the issue has been resolved, the refrigerator is cold and there is no eR dH error message. Thanks to all who shared on this site.
Feb 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
LG Bottom Freezer Refrigerator w/ Swing Freezer Door 22 Cu. Ft. - LRBN22514 Logo
369 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
