Re: What can I do if my screen is locked and I dont know...
U can re access your trio if it is locked by doing a factory reset. Hold down the volume down button and the power button for 30 seconds. It will erase any saved data you have
You need to do a factory reset, follow these instructions:
Step 1. With your tablet turned off, press and hold the volume up (+) button. While holding the volume up (+) button, press the tablet's power button until you see the RCA logo with Nipper and Chipper on the screen. After a few seconds, the screen will change and you will see the Android bot on his back with a caution symbol above him.
Step 2. Now you are going to press and hold the tablet's power button, and without releasing the power button press down on the volume up (+) button. You should then see the screen below.
Step 3. Use the tablet's volume up (+) and down (+) keys to navigate to and select the "wipe data/factory reset" option. To select this option, press the power button.
Step 4. The tablet is going to ask you to confirm your selection. Use the tablet's volume up (+) and down (-) keys to navigate to and select "Yes - delete all user data." Once again, use the power button to select this option.
Step 5. At the bottom of the next screen, you will see "Data wipe complete." Press the power button to restart the system.
Hello there,
From the Zeki website it says do this.
If you have set the screen lock to a password or pin code, and have forgotten the code; you will need to reset you tablet to factory default setting.
Make sure your tablet has a full charge
Press and hold the Volume - button and tap the Reset button
(The reset button is located between the HDMI and USB ports)
Continue holding the Volume - button until the boot screen appears
Release the Volume - button
Use the volume controls to navigate to "Wipe data/Factory reset"
Press the power button to select
Navigate to "Delete all user date"
Your table will take several minutes to reboot to a factory default setting.
its brand new and you forgot everything already if you did the google mail password assist then open that if dont know that or didnt do it can try provider for assistance and most lockouts are either 1hr or 24hr
I don't know my email and password . my brother locked out of my zeepad7.0 and i cant get back into it unless i know my password . I don't know it . so how do i u reset it .
Hold down the power button and the up volume button at the same time for about 30 -60 seconds. The device should go to the factory reset screen if not use power on button to get to the screen. You will lose all data stored. I know this works as I have just done the same to my nieces as she forgot her password.
Sounds like you will need to reset the Archos back to it's factory settings.
When you do this any data/apps etc will be wiped from the system
- Remove any external devices you have attached
- Remove if applicable the external SD card
- Press and hold the power button until the ARCHOS banner is displayed and then release it.
- Press the power button twice (like a mouse double-click) while the banner is still displaying.
- A white Recovery screen should appear within a couple of seconds.
- To move from one option to another, press the power button. To select the highlighted item, hold down on the power button.
You'll want to select the Format System option.
