Question about Samsung Digimax S730 Digital Camera
Short life for the batteries
I went through 8 sets of batteries in 5 days. I need help to have it fixed.
Thank you,
Diane Gross.
  • 3 more comments
  • raretocare Feb 22, 2009
    sir, I too have the same problem of short life of battery.
  • Anonymous Apr 01, 2009
    Short battery life.
  • Anonymous Apr 21, 2009
    Even after installing new batteries the low battery light comes on. I even went to the lithium battery. What is the problem?
  • Anonymous May 12, 2009
    I have the same problem. For those "low" batteries to the camera, I still can use them for other equipment such as Wii remote control.
  • itzChell May 19, 2009
    i can put brand new batteries in the camera and take just a couple pictures, then they die. im getting ready to have a new baby and im afraid i'll have borrow someone elses camera to capture the moment because this camera isnt reliable enough. this camera eats through batteries, and yet i can still use the batteries in other things! apparently you have to have indusrial strength batteries to even get this camera to turn on!
Were you using them in the cold? This can severly reduce battery life.
Posted on Feb 21, 2009
Energizer Lithiums!!!
Posted on Apr 09, 2009
Motorola RDU2080D Short Battery Life
Short battery life can be due to several factors:
1) Short initial charge(s) when the battery was new.
2) Age of battery. Check your date code embossed on the lower portion of the battery below the label. On a three digit code the first number is the year, next two are the week of the year. If a four digit code the first two are the year. Example 142 is 2011 the 42nd week. OR 1142 if a 4-digit code. If you battery is more than 18-24 months old it likely needs replaced.
3) Short charging the battery by putting the radio on the charge too often, or with the radio turned on. Always turn the radio off when charging.
4) Poor connection with the charger. Clean your battery contacts on both the radio and the charger with a pencil eraser.
5) Excessive talking. Heavy talkers radios will run down quickly. It takes more energy to Transmit than to Receive. Using the 5/5/90 rule, your battery should go an 8 hr business day.
Note: There are 3 battery styles available for your radio. The one which comes with the radio is a 1100 mAH battery. There are also two others with higher capacities available.
Best regards.
Oct 26, 2011 | Motorola RDU2080d Two Way Radio
I use aa battery's in my camera but they only take 5 to 10 pics at a this normal or is something wrong like maybe a setting or something? what should i do to fix this?
Digital cameras in general use a lot of battery power; this one in particular is noted for short battery life. When it was new, this camera was supplied with a Lithium Ion battery for longer life; if you're using regular AAs, the battery life will be disappointing. Oh, and cheap batteries from the dollar store might not even work at all!
The most cost effective solution is probably high capacity NiMH rechargeable batteries; get a set of four so that you can have spares on hand. If even that isn't acceptable, look into getting the Lithium Ion one.
If you bought this camera used, the short battery life could easily be the reason the original owner got frustrated with it.
Jan 21, 2011 | Kodak EasyShare Z712 Digital Camera
Short battery life on my samsung j700
short battery life is contributed to these,
1. Old battery 2. Lots of apps running in the background 3. Taking lots of photos 4. Charging the phone when it does not need a full charge 5. Leaving your phone in direct heat or cold 6. Dropping the phone 7. Leaking battery 8. 1 year or more old battery 9. Continuously talking and charging at the same time 10. Ensure to contact your insurance to see if the battery is protected under your plan.
Jan 12, 2011 | Samsung J700 Cellular Phone
Mitsu WS-55859---turned off & only powers up for 2 secs
2,2 is short protection.
98% chance the fuse or fuses (there are two 5 amp pico fuses) that protect the convergence circuit are blown. If you find F9AO4 OR F9AO5 on that board check them--if either is open the STK-393-110 DID IT.
Fairly short life for this chip if it was installed correctly and had heat sink compound applied to it--once in a while you get a bad one.
If this has helped you, rate this solution as I do this here for FREE.
sd tech
Nov 19, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Acer Aspire battery shutting off with no warning.
I am not familiar with this particular model but deal daily with this same issue on the Lenovo is the battery. They can just go bad. Had one yesterday that was fine the day before, now won't hold a charge. It was also less than two years old. They seem to have a shelf life. I would check with ACER to make sure they agree, then order a new battery.
To extend battery life, you need to use the battery up on a regular basis, then recharge all the way. Leaving it plugged in all the time with the battery in shortens battery life.
Jul 31, 2009 | Acer Aspire 5920 AS5920 Notebook
Battery Life Shortened
i have the exzact same problem with my laptop but its coz when u watch a movie, play games, listen to music or if ur using up a fair bit of memory it takes up battery life to store it all
Jul 24, 2009 | LG Dare VX9700 Cell Phone
Short battery life
$orry, theres no fix to this, after a while batterys begin to die and the life becomes shorter. this could be due to leaving it on charge all day and night and not letting it frequently loose and gain charge again. even my laptop battery has began to lose its battery length - but ive had my battery for a long time. purchase a new battery and try to keep from leaving the A/C adapter in over night. you should notice alot longer battery length after that. rate me :)
Aug 25, 2008 | Apple MacBook Mac Notebook
replace the batteries.
Jun 03, 2008 | Uniden Cordless Phone
RCA P50830BL
Hi,the trouble is the power supply for the convergence,it the board that mounts above the two board that lay flat,there is a ic on that board that is heat sinked,part number is 215530,replacing this ic will return the menu and repair the set,the board is green 5 inches wide and 8 inches long.
Mar 13, 2008 | RCA P50830BL 50" Rear Projection...
T-mobile MDA short battery life
Try clearing any programs that may be running in the background.
Apr 23, 2007 | T-Mobile MDA
Samsung Digimax S730 Digital Camera Logo
190 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
