Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
192.168.1.1 the default IP Address of my router is not working.
I want to config my router, what can i do? Please help me.
    Scholar:
  • 85 Answers
Easier to configure if direclty connected using ethernet cable not through wireless laptop or anything wireless.
type in exactly in address bar 192.168.1.1 nothing else(no http or www.) and hit enter. if this doesnt work try to hold the little button near power plug on router for about 10 seconds to reset it and try once again. If it works when you type in the 192.168.1.1 and hit enter you will be prompted for password. user is always linksys and the password by default is admin. then hit enter. now you should be in configuration pages.
Posted on Feb 21, 2009
Connecting canon mx472 to new router. How do I do this?
You have to make sure that the I.P. address, Subnet and Default Gateway are set to match the new routers parameters. (i.e.) I.P.: 192.168.1.44 Subnet: 255.255.255.0
Default Gateway: 192.168.1.254 on the old router.
I.P.: 40.11.120.99 Subnet: 255.255.252.0 Default Gateway: 40.11.1.254
As long as the Subnet & Default Gateways and the I.P config is within the scope of the new router, you should be good. Just remember: All PCs/Laptops will have to reconfigured for the printer's new config also.
Sep 17, 2017 | Canon Office Equipment & Supplies
I'm trying to get into my router config settings
From your computer, go to start, the run, then put in cmd and press ok. This will get you to a black screen.
Put in the following and press enter:
ipconfig /all
Look for the gateway ip address. This is your router ip address. That should get you to the router from your url in a browser.
If this solves your problem, please leave feedback.
Feb 21, 2010 | Computers & Internet
By which ip using i can open the config page of
First connect the router to your PC, click Start menu button on taskbar click run type cmd now type ipconfig, see the Default Gateway address, open your browser, and type the same address...now the admin page will open....For further help please be with us.Thanks for using Fixya...
Nov 05, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Change IP address of Cisco 1841
once in enable mode, goto config mode. then select interface, i.e. f0/0 and then type in the following:
ip address x.x.x.x y.y.y.y where x is your IP address you wish to have and y is the subnet mask
example below:
router#config t
router(config)#int f0/0
router(config-if)ip address 10.0.0.1 255.255.255.0
hope this helps!
Oct 28, 2009 | Cisco 1841 Router
Dhcp setup on a Cisco 2851 router
Let's look at how to configure basic DHCP on an IOS-based router. For this example, we'll start off with the default configuration on a Cisco 2611 router running IOS 12.2. (The configuration should be the same—or very similar—on all IOS-based routers).
To begin, connect the router's Ethernet port to a switch, and connect the switch to a laptop, which will serve as the DHCP client.
To configure Cisco IOS DHCP, follow these steps, which include sample commands:
1.Configure an IP address on the router's Ethernet port, and bring up the interface. (On an existing router, you would have already done this.)
Router(config)# interface ethernet0/0
Router(config-if)#ip address 1.1.1.1 255.0.0.0
Router(config-if)# no shutdown2.Create a DHCP IP address pool for the IP addresses you want to use.
Router(config)# ip dhcp pool mypool3.Specify the network and subnet for the addresses you want to use from the pool.
Router(dhcp-config)# network 1.1.1.0 /8 4.Specify the DNS domain name for the clients.
Router(dhcp-config)#domain-name mydomain.com5.Specify the primary and secondary DNS servers.
Router(dhcp-config)#dns-server 1.1.1.10 1.1.1.116.Specify the default router (i.e., default gateway).
Router(dhcp-config)#default-router 1.1.1.17.Specify the lease duration for the addresses you're using from the pool.
Router(dhcp-config)#lease 78.Exit Pool Configuration Mode.
Router(dhcp-config)#exit
I hope this is helpfull for you.
Thanks
Vikrant
Oct 26, 2009 | Computers & Internet
Cisco ASA 5505 Firewall
1. Change your PCs default gateway to your firewalls' internal IP
2. configure the nameservers on your ASA
Then internet will work fine.
May 23, 2009 | Cisco ASA 5510 Anti-X Edition...
Sending DHCP request across diffrent vlans
Hmm... on your DHCP server, try setting the "default router" IP for each pool to be the VLAN ID on the switch.
scope 172.16.0.0 /24
router 172.16.0.1
scope 10.20.8.0 /22
router 10.20.8.1
I think the DHCP replies aren't going back where they should. I've never done this without a router doing all the DHCP, but it does work and i've done it many times. Your config looks spot on for the switch.
Feb 01, 2009 | Cisco Catalyst 3750E-48PD
Changing default gateway
how are you connecting to the router?
Is it by the serial cable or network cable ?
Sep 23, 2008 | Cisco 2501 Router
CONNECTION TO ROUTER WGR614 V6
Do u have any wireless security set on ur router ?
do a IP config/all in MS Dos window. then, note down the default gateways IP address. Then, open a browser and put the IP in the address bar. this will open ur Router's Config page.
Go under security to see if u have WEP or WAP turned on.
Apr 17, 2008 | NetGear WGR614 Wireless Router
Wireless conections
Try the http://192.168.1.1 to access the router config page (needs Ethernet cable to be connected to the Router)
If config page still does not appear, then check your Internet Explorer settings> Security Level (not set to custom) If it is, then choose RESET ALL ZONES TO DEFAULT LEVEL and then try this address again. It worked for me.
Dec 26, 2007 | Zyxel Prestige 660HW Wireless Router...
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
340 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
