Question about Sony MDS-JE470 Mini Disc Player
Din Unlock C71
Dear Sir,
I have a SONY MDS-JE470, I have been trying to hook it up to the sound card of my computer. I bought a wire that has one end RCA male ends & the other end has a pin. The sound card is the SOUND BLASTER X-FI XTREME Audio Model SB790EF.
There are four holes athe back of it 3 holes for the speakes an one hole for the MIKE tha says DIGITAL_IO. On the front of the computer there is a headphone port and a mike port. I am using ULTIMATE VISTA 64 BIT I would like to be able to record from the computer to the MDS can you please tell me how to record from the computer to the MDS using the sound card please? laysman's terms please.
    Sniper:
  • 87 Answers
your deck is expecting a digital signal provided by optical cable.
Hence the error message you see. If you want to record using RCA cables, you will have to set your MD recoder so to use analog input.
Press the INPUT key repeatedly to select the Analog input, then connect your RCA cable to the Analog input and start recording.
You may have to adjust the recoding level (or volume if you will).
OR you get an optical cable and then use the Digital Input 1 or 2.
See page 11 of your user manual for detailed instructions.
Cheers
Posted on Feb 21, 2009
    Habit-Forming:
  • 99 Answers
HW_Dude is spot on with his answer to your porblem
Posted on May 02, 2016
Din unlock c71
the input source you have selected is not working. If digital it might be a copy guarded source which the deck cannot read...
If you get fancier and are trying to record the optical output from a newer device like a 5.1 or 7.1 receiver although the signal will go through the MD deck cannot decode the advanced optical signal. There are adaptor boxes on eBay which decode 5.1 & 7.1 optical signals to an optical signal the older MD can read and record from.
Try selecting another source like analog RCA. The digital stuff I mentioned applies to digital RCA and Optical Cables like toslink.
Feb 08, 2014 | Sony MDS-JE520 Mini Disc Player
Jd520 error read c71
DIN unlock is related to a digital clock being missing so the unit is looking for a digital input of some kind. Since your laptop is putting out analog change the MD input to analog and of course use the correct inputs. A 1/8" or 3.5mm audio cable may fit into an optical port but it will never work in that way.
Nov 14, 2012 | Sony MDS-JE520 Mini Disc Player
My mini disc player is displaying din unlock c71 i cannot record
You have probably chosen a source which is not active, there are other reasons but usually your selector switch is set to a dead input with nothing to record from.
Jan 01, 2011 | Sony MDS-JE480 Mini Disc Player
I'm trying to record on to my mini disc recorded (sony MDS JB940) and it's flashing Din Unlock c71. how can i solve this problem?
"The definiton in the manual suggests you are trying to record a digital bitstream that is either dead or incompatible with the recorder."
That is completely wrong. DIN UNLOCK means what the first poster said - that you are trying to make a digital copy of a digital copy. You cannot (for legal reasons). Record via analog.
ABSOLUTELY DO NOT TRY TO CLEAN YOUR LENS WITH ALCOHOL AND A Q-TIP. It has nothing whatsoever to do with your problem and you may well damage or destroy the lens or the transport.
Oct 20, 2010 | Sony MDS-JB940 Mini Disc Player
Whats a c71 din unlock plz if any 1 can help me just email me plz
Usually, you are trying to record DIGITALLY from a source that has 'copy protection'. Try recording thru the Analog jacks, and you shouldn't have this problem.
May 12, 2010 | Sony MDS-JE330 Mini Disc Player
C71/DIN UNLOCK
The definiton in the manual suggests you are trying to record a digital bitstream that is either dead or incompatible with the recorder. Go analog.
What happens if you skip the receiver? Be advised that anything coming in digitally through a cable/satellite box may be muliti-channel and convertible by the player to its native 44.1 khz sampling rate.
Mar 31, 2010 | Sony RCD-W500C 5-Disc CD Recorder
Din Unlock - Unable to record
You must have the unit switched to "DIGITAL" input - switch it to "ANALOG" and record that way. The "DIN UNLOCK" is when you have the lack of a proper digital signal, or a digital signal with copy protection, like you cannot make a digital copy of a digital Minidisc, etc...Does that make sense? Let me know if the "Analog" setting works for you. Good luck.
Nov 07, 2009 | Sony MDS-JE330 Mini Disc Player
SONY MDS-JE480 "C71 - DIN Unlock" persistent problem
I get the DIN UNLOCK with you try to make a copy of a digital copy.
Jun 29, 2009 | Sony MDS-JE470 Mini Disc Player
Won't record...says din lock
I'd say you have the digital input selected. The player does not see a digital signal and gives such message.
Select the analog input and you should be able to record.
Hope this helps.
Jan 13, 2009 | Sony MDS-JE470 Mini Disc Player
Din unlock
Hi - You can download the manual from the link underlined in blue below:
MDS-JE480
The error you have is probably:
This means that you are trying to record from the Digital Input, if you want to record from an analogue input do the following:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 27, 2008 | Sony MDS-JE480 Mini Disc Player
Sony MDS-JE470 Mini Disc Player Logo
2,494 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
