Question about Sanyo DP32648 32 in. LCD TV
MY TV SANYO DP32648 AMPLIFIES ANY RED IN THE BACKGROUND
ALL THE PICTURE CONTROLS DO NOT RESPOND WELL, ESPECIALLY WHEN I CHANGE CHANNELS.
IT WOULD BE HELPFULL IF THE HANDBOOK GAVE SOME INSTRUCTIONS AS TO HOW THE TV IPICTURE CONTROLS ARE SUPPOSED TO WORK.
I USE CHARTER CABLE AND THEIR HD TV OPTION. I WAS TOLD THAT THE IMAGES WOULD BE UNIFORM.
  • tworthylake Feb 22, 2009
    CAN YOU DESCRIBE THE RESULTS YOU EXPECT TO GET WHEN YOU USE THE PICTURE CONTROLS (BRIGHTNESS, TINT, COLOR, ETC..)
  • 71 Answers
Go on to the site. and check specigifactions
Posted on Mar 05, 2009
Sound no picture on Sanyo 32 inch flat tv model number DP32648-02 how long has this been a problem for Sanyo?
Circuits fail with time no matter who the manufacturer is. That's what warranties are for. If yours is no long in warranty you can get a replacement T-con board and replace it yourself. Get the part from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Dec 01, 2016 | Sanyo Televison & Video
My sanyo hdtv shows no pictures when you turn it on (the screen is black) but you can hear the audio. The remote control can change the channels and volume up&down but the picture won't show
Good day!
The problem of your TV could be the inverter board or the cold cathode light is busted.
Follow this instruction on how to fix that problem:
  1. Remove the back cover of your TV.
  2. Look for the Inverter board.
Inverter board looks like this:
3. Check the input voltage of the inverter board if have 24vdc.Using multimeter (range on DC)
4. If you have 24vdc,check the output voltage of the inverter board it should have 500vdc.
5. If you don't have 500vdc output on the inverter,replace it.
6. If the you have the output voltage on it,the problem could be the busted cold cathode light (C.C.T).Replace it.
I hope this solution will be helpful.Thank you and don't forget to rate my answer.
May 07, 2011 | Sanyo DP32648 32 in. LCD TV
Sanyo lcd32k30td tv has blue screen , get sound no picture , cannot change channels or use any controls on remote or side of tv.
switch it off for 10 seconds .. then press button TV/AV
its probably due to power fluctuation ..
if the problem occurs check for local warranty service or service center
Mar 29, 2011 | Sanyo DS32920 32" TV
I have a Sanyo DP32648 that keeps losing only one channel in the program. When the TV is turned off, that channel disappears from the program. I have to manually reboot the entire list. How can I solve...
It sounds like there is some electrical noise interference that would not be "fixable". If though, we reconfigure the way that they are connected together, we may be able to avoid the noise.
Instead of allowing the antenna signal to "pass through" the 625 we will skip it.
After following the directions, switching between satellite and antenna will be done by selecting on the SANYO "Input 1" for satellite, and selecting "Ant" for antenna. K?
Try this:
From the 625 Tuner 1- using RCA cables (a.k.a. composite cables, or red, white, yellow cable), connect to "Input 1" on the Sanyo TV. To see composite cables go to http://www.wowvision.tv/settingsandconnections.htm
Next, remove the coaxial cable between the Sat box and TV. (Sanyo "Ant. In" port and 625 "Out to TV" port) Set that cable aside.
Now, remove the incoming antenna cable from the 625 "Ant. In" port, and connect it to the Sanyo's "Antenna In" port.
Finally, scan for channels and check for the presence of CBS.
Once verified, test the TV by turning off and on.
Turn on the satellite receiver and switch Sanyo to "Input 1" to verify sat picture.
I believe this solution will satisfy your needs. Please let me know if it doesn't work, and I will need to talk to you about signal strengths, again.
God bless,
Highdefjeff
Jun 13, 2010 | Sanyo DP32648 32 in. LCD TV
32 ''Sanyo DP32648 TV has horizontal line running across screen
If you do not have any bad capacitors Problem will be the Display Panel
Call Encompass Parts Distribution or visit their website and type in your Model number 1-800-638-3328
Apr 28, 2010 | Sanyo Televison & Video
New flatscreen Sanyo tv. Picture is to big for the screen
use the picture button to change the shape, Most likely you have it set to picture 3 which would cause that.
Jul 04, 2009 | Sanyo DP32648 32 in. LCD TV
Digital channels
It's possible the stations you have in your area
have switched from UHF to VHF or vise-versa
I had the same problem and have lost one channel completely
You didn't clarify if your using an antenna or
cable qam so I assumed you are using antenna.
Youll need to check your antenna to see if it
supports both UHF vhf if it only supports one
that could be your problem .
go to antennaweb.org it will help you determine
what stations are avalible to you .
Jun 13, 2009 | Sanyo DS27510 27" TV
How do I change icon picture?
You can't change the icon picture for Watch TV or Watch DVD. The pictures that you can change are the background and the favorite channels.
Hope this helps,
81
P.S. I think that it should be an option!
Feb 01, 2009 | Logitech Harmony 1000 LCD Touchscreen...
Sanyo DP32648 32 in. LCD TV Logo
113 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
