Question about Acer Aspire 5100-3357 Notebook
Power wont turn on acer aspire 5100
The power wont turn on i dont know if it is not charging or what the problem is please help
  • Anonymous Feb 24, 2009
    my laptop will not power on at all i do not know what the problem is..
    Sergeant:
    Champion:
  • 283 Answers
Check 1st your charger if working.try other charger
Posted on Feb 21, 2009
I have an Acer Aspire 5100 and on the front is an indicator light next to a light bulb icon and it never turns off, how can I turn it off?
hi-I have 2 of these 5100 notebooks-indicator lights are as follows -left is bluetooth next one is wireless lan, next one is power on,and the last one is battery. only way I know is to unplug it when not in usand the light will go off. if plugged in the light will stay on showing charging(orange) and charged (green). me i just put somthing in front of the light to block it from lighting my room at night.yes, they should have made it turn off at full charge, but they did not. good luck with that-hope this was helpful. have a great day!
Jan 27, 2010 | Acer Aspire 5100 Notebook
My Acer Aspire 5100 just went blank. There is a
Generally, an indication that the battery is critically low. It appears that the AC adapter is not powering the system and not charging the battery.
Jan 09, 2010 | Acer Aspire 5100 Notebook
Acer aspire 1500 will not turn on
Try removing the battery and running the power directly through the power outlet. HP laptop dv6000 has the same problem.
Nov 06, 2009 | Acer Aspire 5100 Notebook
My Acer Aspire 5100 wont start up correctly
Try removing the battery and connecting the AC adapter then see if it boots up.
Reinstall the battery and keep the AC adapter connected and see if it boots up, if so leave it charge the battery for several hours.
If none of these work, get a replacement as there is a more segnificant problem.
I hope this helps.
Good Luck.
Mar 14, 2009 | Acer Aspire 5100-5033 Notebook
Acer aspire 3694 wont startup
It means there is no power getting to your board
Aug 31, 2008 | Acer Aspire 3690-2196 Notebook
Power cuts off for acer aspire 5100
I,d suspect your problem will lie with, the systems CPU ( Processor ) or a component Overheating on the systems Motherboard. I would,nt suspect the Power Supply personally. unless your batterys not charging.
Mike @ compurepair.
Apr 22, 2008 | Acer Aspire 5100 Notebook
Acer aspire 5100 start up problem
If you dont hear any beeps. Then most likely the motherboard is faulty.
Replacement parts can be ordered from www.acerparts.com
If you need more assisntace, let me know.
Mar 27, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Red Battery Light
The Aspires should have no issue booting without the battery installed. Have you done a static reset? (i.e. hold the power switch for 20/30 seconds without power or battery in) And the voltage range on the Aspire 5100 should be +19v - +20.5v on the inner part of the connector so it might be worth checking that the power adapter is outputing correctly.
If it works without battery, then it can be checked by testing the voltage between pins 1 and 6 on the battery (the ones either end) and should be 7.5v or above if the battery is charging correctly.
Hope that gives you a starting point, if you've done all those things already then appologies and best of luck with it.
Dec 10, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100-3357 Notebook Logo
346 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
