Question about Whirlpool Duet GHW9150P Front Load Washer
When I push and hold start nothing happens
When I push the control on button the lights come on but then the start button does not engage
  • Anonymous Feb 21, 2009
    Same here nothing happens when I push start button. Outlet and breaker are fine. I think its the computer (mother board).
    President:
  • Whirlpool Master
  • 2,651 Answers
Can also be an issue with t door lock/latch assy, if it doeesnt recognize the door closed it wont start
Posted on Feb 21, 2009
  • Ross Taylor Aug 15, 2012
    Ronald is right on. I just replace the door gasket on a Whirlpool. The power button worked , but I only got two beeps when pressing start. I opened and closed with door with gusto and it is working fine.
When I push the start button on my dishwasher, the "hold 3 sec" light blinks but nothing happens and no other buttons work.
It sounds like the control panel is locked. See if one of the buttons says lock and hold it down for at lest 3 seconds. If the control is locked, that should unlock it. Its a child safety feature.
Apr 22, 2015 | Dishwashers
I am traveling and my sensotouch 3d razor wll not unlock or come on
If the travel lock is engaged, simply press and hold in the power button fro 5 seconds to unlock it
Feb 06, 2015 | Norelco SensoTouch 3D 1290X Electric Razor
I have a 94 Acura Integra LS 1.8 DOHC. I bought it 4 months ago. The cruise control and horn don't work. I would be very appreciative of any advice that may help. The green light on the cruise button...
The cruise control requires input from the speed sensor(s) in order to engage. This may not be happening.
The horn relay may be clicking but the horn may have failed. The horn is located under the hood.
May 22, 2014 | Cars & Trucks
My car won't start
are you pushing and holding the button? don't just let go.
Feb 09, 2014 | 2006 Cadillac STS
Ignition problem,turn key but nothing happens?
First thing to do is look at the dash lights when you put the switch in START position. If they blink or dim, you may have a faulty battery or poor connectivity.
Next try jumping the starter. You'll find a starter jumper at almost any auto parts. If you get no result then the problem is with the starter, If the starter turns then the problem is in the starting circuit from the switch to the starter relay.
Dec 05, 2011 | 1998 Jeep Cherokee
Control Locked
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
2001 Chevy 4WD button lights don't come on - 4WD wont engage
check the solenoid on the front chunk these vehicles have had a lot of problems with these solenoids. have personally replaced about 10 of these on 98-02 models.
Aug 26, 2009 | 2001 Chevrolet Silverado 1500
I have a brand new acer aspire one. A moment ago, when I wanted to open it, I saw that the green light on its top right, that is, at its "start" button was on, and the battery was a bit displaced at one...
Most likely your laptop is going into sleep mode. Lots of them do not like sleep mode if nothing happens when you push the power button try to hold it down for about 5 sec. your computer should power off and then you can start as normal. If this problem persists change the options in your control panel to turn sleep mode off. That should solve it.
Dec 18, 2008 | Computers & Internet
''Control Lock'' won't ''unlock''
Press and hold the "End of Cycle Signal" button to lock or unlock the control panel. The instructions should be printed directly below this button. I hope this helps you.
Nov 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light on-door opens-won't start
Press 'control' + 'pause:lock' +
'temperature' for 5 seconds
OR
'end of cycle' for 5 seconds. Tell me which worked & rate me pl.
Apr 16, 2008 | Whirlpool GHW9150 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
232 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
