Question about Acer Aspire™ T180 PC Desktop
Computer shuts down on its own hard drive just completly shuts off have to hit power button to restart it. I am thinking that it could be power supply going bad because at times it does have a slight burning smell coming from the hard drive. Do you think this could be caused from a bad power supply?
    Problem Solver:
  • 15 Answers
Maybe ur power supply is bad but i think u better have disk of fix it utilities or system mechanic.and u have to run a virus check up and always update ur antivirus.I recomend kaspersky internet security.and 1 more advise,i think ur computer shut down improperly koz ur memory partition is bad and maybe ur computer is now at risk.i think u better send ur computer to the nearest computer shop and ask to repair the system.Or ur computer will explode shockedly or may stop it to operating like usual.i send my regards to u and ur family.
Posted on Feb 23, 2009
    Novelist:
  • 90 Answers
Hello mr_nasty_72,
Your problem could be several things. Your hard drive is either over 90 percent full and the windows swap file is dumping the computer to shut down. the hard drive has a bad spot i it and when the system writes to it, then computer shuts down. Your memory has a bad spot in it and when the file useage of the memory gets high enough and finds the badspot, the computer shuts down due to the error. I would run a memory test program on the memory to ake sure it is not a memory error. Also rin a utility like spinrite on the hard drive and see if it can repair any bad sectors it finde and recovers any lost information on the drive. If your computer is new enough you cn go into the bios setup and look at the system utility for the power and fan system on the motherboard. This will tell you if the power supply is putting out the correct power voltage for the system. Regards, rcampsr
Posted on Feb 21, 2009
I did a system restore and it says that it was unsussessful and shuts down. I restart the computer and it says unsussessful and shuts down. How do I fix my computer?
There should have been a recovery CD that came with your E-Machine. Put that in and restart the computer. If you've already done that, then you might not have the CD drive set as a first boot priority. restart the computer and look to see what button it says to push to enter "Setup." If you can't find it, try the "Del" button. restart and right away start hitting "Del" over and over until it says it's entering setup or it actually enters setup. find where it says boot. you'll have to use the arrows, the mouse won't work. go to boot and look for "Priority" hit enter and you'll see some options for 1st, 2nd, 3rd boot device. make the first one the CDROM and the second the HDD or hard drive. Then hit F10 to save and exit it'll restart and should restore then.
Dec 08, 2010 | E-Machines (T2958) PC Desktop
Shutting down almost instantly when powered on, sometime runs for ever , then on a restart it just shuts down. anytime i hit restart it shuts down wont start up again unless i power it completely off...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
problems
Nov 17, 2010 | Acer Aspire L100 PC Desktop
How to reboot computer
hi
  • Decide what kind of reboot you are going to do. A soft reboot is performed the way you are “supposed” to do it. For a soft Windows reboot, go to the Start menu and select “Shut Down” or “Restart.” The computer will then shut itself down. Clicking “Restart” makes it boot up without further intervention from you.
  • Step 2 Perform a hard reboot by pushing the computer’s power button and holding it until the computer shuts down. Wait 45 seconds and restart the computer by pushing the power button again. You may have to start up in safe mode, but that also allows you the chance to restart properly or work on programs in a safer way. This method may cause you to lose data or mess up the operation of some of your programs. But it may be the only option if your computer's hard drive is frozen.
  • Step 3 Power down all of the computer's components. Shut off all of the peripherals you have attached to your computer, and disconnect the cables. Then, plug all of the peripherals back in, and restart your computer. This can often solve problems with your hard drive.
  • Step 4 Purchase and install a program such as Drive Reboot Restore PC 6.0 that streamlines the hard drive reboot process. These applications help prevent the problems that can develop after repeated computer use. They also ensure that your hard drive maintains the configuration you want each time you turn it on.
  • Step 5 Investigate what the problem may be with your hard drive. Because of its delicate nature, your hard drive can very easily be thrown off.
  • Jul 04, 2010 | Compaq Pavilion ZT3280US Notebook
    Bis failure, media cable and insert boot disk
    first step to check whether its a hard ware or software issue .........disconnect all the external devices and disconnect the power cable from the back of the computer , then press and hold the power button for 10-12 secs with the power cable disconnected and then reconncet only the power cable and restart the computer and check whether it restarts or not.................shut down the computer and while u restart the computer keep on tapping f8 key on the keyboard and on advance boot options select last known good configuration and hit enter and see whether it restarts or not .......................after that shut down the computer and while u restart the computer keep on tapping f9 key on the keyboard and do the diagonistic test and see wat error do u get if u get any biohd-8 then the hard has gone bad , if u get any other error then jast open the tower and reseat the hard drive and the sata cables , the hard drive cable will be jst below the dc/dvd driive looks lik a bunch of multi colured cables .............and also reseat the sata cables i.e a red ribbion like cables and restart the computer and see ....
    Jun 08, 2010 | MPC Computers ClientPro 345 G PC Desktop
    Installed a new hard drive. Now the system tells me it can't find the operating system. I checked the connections and they seem to be connected ok. Any ideas what the problem?
    if it is ide haed drive you have to make sure that the red wire on cabel is on pin 1 as well as board ok check the power connections as well
    Apr 16, 2010 | ASUS A7N8X Motherboard
    Format laptop lenovo y550
    Note: Format would delete all of the data(like pictures, documents.) from the computer. Make sure, you back up all of your important data before formating the hard drive.
    1. Insert operating system disk. 2. Shut down and restart the computer.As soon as, you restart the computer, start tapping 'Spacebar' key. Now, this would start loading from disk. 3.Hit F8 to accept the license agreement. 4.Hit enter 5. Enter Enter again and follow the on screen instruction and this would format your hard drive.
    Note: once you format the hard drive, you would need to install drivers as well. Make sure you have the drivers and utilities disk as well.
    Apr 15, 2010 | ASUS Computers & Internet
    Computer shuts down on its own hard drive just completly shuts off have to hit power button to restart it. I am thinking that it could be power supply going bad because at times it does have a slight...
    Your notebook is overheating. Do not situate it on bed or on your lap because that blocks the vents. And try air duster on the vents.
    You should be thankful that it shuts down - you sure do not want a mysterious explosion or a fire. It is a special defensive measure.
    Apr 25, 2009 | HP Pavilion DV6700Z Notebook
    How to rebot acer 4220 laptop
    usually holding down the power button for a long time will force a reboot. I am not sure if that is what your asking
    Dec 05, 2008 | Computers & Internet
    I want to reboot my computer acer. How can I do that
    Reboot basically means to "restart" the computer. You have a soft reboot which means hitting the reset button on the front of the computer or going to the start, shut down, restart computer. A hard reboot is shutting the system off completely and then turning it back on.
    Nov 29, 2008 | Acer Computers & Internet
    Acer Aspire™ T180 PC Desktop Logo
    220 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
