Question about Amana Refrigerators
Inside lights on but temp gauage says -
Has two temp gauges side by side in front at top inside, they both read -. Model # is ABB2524DEQ and S/N is 1055011GA
    President:
  • Amana Master
  • 2,651 Answers
Try unplugging the unit. then resetting the temp, sounds as if you encounterrd a power surge of some sorts.
Posted on Feb 21, 2009
Dash gauges read full then it will say 1/2 full or anti lock brake light comes. Also reads outside temp way off
Probably the inside harness of the dash board is lose, take it apart and make sure everything in in there tight.
Hope this helps.
Oct 04, 2016 | Cars & Trucks
I replaced my water pump in my 1999 gmc yukon my check gauge light stayed on and temp gauge stayed over to hot side. can i reset it?
Not exactly.
The check gauge warning light is on because the temp gauge is reading hot.
Does the temp gauge read hot as soon as you turn the key switch on, or not until the engine as run for a few minutes ?
If it reads hot without the engine being started, there may be a short in the wiring or the sensor may have failed.
Apr 19, 2013 | 1999 GMC Yukon
Temperature gauge on 2000 catera is staying on cold as if caris not heating up
If it is actually warm, but the gauage has not moved, you probably have a bad temp sensor that feeds the guage. On some cars there are 2 temp sensors, 1 for the computer to it knows how much fuel to give based on coldness, and one for the guage that just shows you in the dash what the temp is. The other 2 ideas would be a bad gauge and a bad wire/cable from the sensor to the gauge. There is not much else it could be if in fact the reading is wrong.
Sep 26, 2012 | 2001 Daewoo Leganza
Temp gauge reads half but there is no heat blowing
the door inside the heater control box unit may be stuck shut. It runs off a vacuum port to open
Jan 24, 2010 | 1992 Nissan Stanza
Temperature gauge is inaccurate and check engine light comes on but its not over heating and everything else is fine can it be a sensor ? The temperatue gauage didn't read anything for months but now...
Have you checked the antifreeze level lately? Low antifreeze will cause a temp sensor to give false readings. Does your heater work OK, as in does it blow hot air when heater is on? that is another symptom of low antifreeze.
As far as the check engine light coming off and on, I would bet it is the oxygen sensor that might need to be replaced.
Oct 20, 2009 | 1985 Chevrolet Monte Carlo
92 k1500 5.7L tbi fuel gauge always reads full and temp gauge always stuck down.... any suggestions
Two possible problems.... the temp gauge wire is a single green wire attatched to the driver's side head (no1 bank) near the front in the side (in front of plug #1) ground it and your gauge should go to full hot,,, same with the fuel gauge, if you unplug it at the tank it should go to empty, or visa versa... if the gauges respond, replace the sending units, if they don't, replave the instrument panel
Sep 12, 2009 | Chevrolet Silverado 1500 Cars & Trucks
Stuff in the freezer is melting, motor is running, no cold
turn your freezer temp dial to off and wait 30 seconds, then turn it back on to max setting. if you have temp gauage you can try to check temp inside freezer, if not cold enough (less than 30 degrees) you could be losing freon gas. you need to call technician.
Sep 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The indicator light that give miliage/temp/ will not come on. 2002 dodge intrepid
Are you trying to say that the light that illuminates the temp gauage and the speedometer gauge don't come on? If so you need to replace the bulbs from behind the instrument cluster. If help needed reply on this post.
Mar 25, 2009 | 2002 Dodge Intrepid
Dash instruments stop working
1998 plymouth voyagar no headlight , no inside lights, no water temp, no gas gauage
Dec 28, 2008 | 1991 Plymouth Grand Voyager
The gauges are not working....everything else works
if you can remove the gauage panel and check the conections.first check under the hood gauages first hope this help
Aug 04, 2008 | 2002 Chevrolet Cavalier Coupe
Refrigerators Logo
67 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
