Question about 2wire Wireless-G 802.11g ADSL Gateway
HOW DO I DO I LOG ON MY 2WIRE WIRELESS. I LOOKED AT MY SETING ON PROPERTIES BUT THERE IS ON IP ADRESS OR SUBMASK. BUT I CAN GET ON THE NET. HOW DO GET MY PC TO DETECT MY SETTINGS?
  • Ved Pradhan May 11, 2010
    hi..
    u need to tell me abit more..u can log in to the internet but cannot see you settings is that correct?or you are trying to change settings in ur 2wire box...the description is quite vague..can u explain a bit more..
    vedhick
  • 4,338 Answers
Open a browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.Once you are on the setup page, you can see all your settings.
If you want the wireless key, it is located on the label on bottom of the modem.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Mar 03, 2009
My hp laptop had its memory wiped back to factory specs how do i give it a valid ip address so it can connect to my homenet 4a4e wireless
Check your router and confirm ip adress, and type manual ip adress on your wireless network connection properties in your computer.
Apr 13, 2012 | Computers & Internet
I cant open my WIRELESS ROUTER |WL-520G - RT (WL520GC) on my browser; if i open the default gateway the isp modem settings pops out not my asus router seting... pls hep
Hi!
I tried to figure out some explanation, and I think it's possible that both WAN side of the router and LAN side of it have same types od ip adresses, maybe the default 192.168.1.***. That means that the WAN port of the Router, the ethernet port of the modem, the wireless and LAN ports of the router have same tuype of adresses, maybe all asigned by DHCP.
To be sure, I suggest you to:
1. turn of the modem
2. check that the network connection obtains ip adress automatically
3. in a dos prompt (START - RUN -CMD) type IPCONFIG, it will return among other infos the adress of the default gateway.
4. now type that adress in the browser.
5. if it works, log on to the router and change the LAN settings so that the adresses used in the LAN will be different from the WAN, let's say 10.10.10.1 and so on
Aug 06, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
I want to modify ip adresse
Use notepad to write the following:
{IP;2,192,168,001,201'}
{IP;3,000,000,000,000'}
{IP;4,255,255,255,000'}
{IS;1,09100'}
{XJ;Termine'}
and print it to your printer
These will change your
IP adress
Gateway
your submask
activate and deactivate the port with an adress at 9100
and at the end display Termin?
respectiveley
Jul 21, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
My network seting in pc not working tel me please the manualy seting for windows xp
On the desktop right click my network places and go to properties. Then if it is a desktop right click on the local area connection and go to properties scroll down to internet protocol click on it then go to properties. A new box will open change from obtain to use the following IP address. the ip address is usually a 192.168 number defined by your router. subnet is 255.255.255.0 the gateway is the ip address of your router like 192.168.1.1 The dns can be used as 8.8.8.8 and 8.8.4.4 that is googles public DNS server hit ok. If your computer is connected wireless then same thing except right click on wireless not local area connection
Mar 07, 2011 | Computers & Internet
Im trying to get my ps3 connected to my router wireless.. however when i entered the only 2 codes on the router, it would not obtain my ip adress. so it fails the attemp. HOW DO I FIND THE CORRECT WPA...
You can check the passphrase when you access the router page:
  • Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
  • Click the Home Networking tab at the top of the 2Wire Home page.
  • Click on Wireless Settings. then click EDIT SETTINGS located on the right panel.
  • Here you will be able to fine the setting for your wireless connection
  • You can change the SSID, Wireless Channel, Wireless Security, and Network Key
  • If the Wireless Security Key uses the default, the Passphrase is the 10 digits located underneath the router under the S/N.
Thanks for using Fixya.
Mar 20, 2010 | 2wire 2700HG-B Router (2700HGB)
Do you have internet explore ip address. it starts 192"?
what do you mean by internet explore ip?? just your computers IP?? or your routers IP??
normally the IP would be 192.168.0.XX submask is 255.255.2550
but if you just need to know your ip for now just go to START>RUN and type CMD that will open command prompt ( quick way is windows sign on keyboard + R ) to open RUN
once in CMD you type ipconfig then you'll see your IP adress, subnet mask and default gateway. hope this helps
Mar 05, 2010 | 2wire Wireless-G 802.11g ADSL Gateway
Check IP adress, Sub-net Mask and Gateway adress
open rum command and type command ......
after open command prompt ....
type ipconfig and enter......
ok
you see your ip address subnet...
Sep 02, 2009 | Linksys WCG200 Wireless Router
I dont know crouter configuration
Hai,
Look at your computer's IP configuration. Go to Network and Dial-up Connections, RIGHT CLICK on your network and pick PROPERTIES. Click on the Internet TCP/IP protocol, then click on the PROPERTIES button. Make sure that your settings are OBTAIN IP ADDRESS AUTOMATICALLY.
Then get into your status screen and look at the GATEWAY address. Is that 192.168.0.1 ?
(If you are using Windows 95/98/ME, then go to RUN and go to WINIPCFG)
You can also use the COMMAND PROMPT and type IPCONFIG and it will show the Gateway address. If the Gateway address is slightly different, then try to get into it at that address.
Also from the COMMAND PROMPT, (or MS-DOS window) you can use the PING command. Just type PING 192.168.0.1. If your router responds, you might be OK.
Look at the lights on your ethernet card. Is it GREEN, or does it show YELLOW.
Try rebooting your computer and using PING again.
Then the problem presist it's possible that this Router is NO GOOD.
Hope this Helped!
Aug 27, 2009 | Computers & Internet
I have a 2wire 1701 and its blocking/not letting some programs either connect or update. Help
log into the 2wire with the defalt gateway ip adress to get that go to start and then run type in (command) in the run box or (CMD) same thing when the black box comes up type in ( ipconfig /all) it will give you a network makeup list you are looking for the defalt gateway type in the defalt gateway ip adressa into an internet explorer adress box at the top EXAMPLE (192.168.1.1) it will bring you to the login screen for the router from there you will have to look around and find the firewall and turn it off windows has its own dont worry about the one in the 2 wire im guessing you have dsl the password for the login may be plank it may be admin it may be password it might even be on the bottom of the 2wire itself if you find yourself not bing able to find it put your 2wire molel number and the words defal login in a google search
Jan 20, 2009 | Computers & Internet
Locking the connection
you will need the ip adress of the router and the user name and password enter ip adress in enternet browser it might ask for user name and password Then you would find a seting to protect it by a WEP password.
Jan 02, 2009 | Linksys WRT160N Wireless Router
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
13,353 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
