Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Large ice block is forming behind the fruit drawer.
There is a large amount of ice forming behind the fruit drawer. It seems to be originating from a flexible pipe located along the back. As the ice melts it tends to from a puddle on the floor.
  • DicksonMR Apr 17, 2009
    same problem, but after putting heater wire into drain tube and replacing evaporator, testing sensors, and seting unit at recommended 0 / 38 degree settings, still get Ice forming in the drain tray that eventually overflows off the drain tray into the refrig behind the fruit/veggie drawers. Refrig tested and replaced twice after evaporator was installed, compressor, everything testing out fine. Seems to me if there was a way to "heat" the entire drain tray during cycle off periods, problem would be solved
    Sniper:
  • 56 Answers
I assume you have a model 650 or 550. Your drain line has clogged then frozen. You need to defrost the ice then clear the drain line. I usually knock a majority of ice away then defrost the rest. Once you have defrosted the line you need to clear it. I use high pressure nitrogen to blow them out, but a turkey baster will do just fine. Fill the turkey baster with water, disconnect the drain line from the drain trough. While holding the baster into the drain line squeeze the bulb to force the water into the line. It may take a couple of tries. Reconnect the drain to the drain trough and you should be all set. If you let this go too long the insulation may be saturated and you will have to have a tech install a drain tube heater kit. If you have questions call the factory at 800-222-7820 or go online to the locator page: http://subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code
Posted on Feb 22, 2009
Definition of a citrus fruit
Fruit with citrus acid. Fruit high in acidity. Lemon, lime, orange.
Oct 10, 2014 | Cooking
Ice forms as large block not in cubes
Defrost thermostat is bad. Defrost element is staying on for too long raising up temperature causing ice to melt.
Mar 26, 2014 | Fisher and Paykel Active Smart E522B...
What are the downsides to bananas?
: Although bananas are a very healthy fruit, eating too many bananas can pose risk on your health:
Bananas contain a large amount of sugars, which is bad for your teeth.
Bananas contain a large amount of potassium (one banana has 25% of daily potassium requirements). Eating too much potassium can lead to hyperkalemia, a condition that makes you have diarrhea, loss of strength, nausea, and abnormal heart rhythm.
Jan 17, 2013 | Cooking
Top drawer of freezer seems to work but large bottom drawer not freezing even at -5degrees. Can this be fixed?
This problem seems to be two sided. A refrigerator defrost it is supposed to take the water from defrost down a pipe located behind the freezer rear wall to a pan below the refrigerator where there is a fan blowing warm air over the water to evaporate back into your home or business. If that drain is blocked your refrigerator will accumulate a large block of ice and frost behind the rear panel of freezer and temperatures will warm considerably in fresh food compartment and freezer. Here is one site I want you to read over=> Leaking Refrigerators Just What may Be Happening and here=> Leaking Refrigerators here is a link to a service manual=> LFX25960xx Service Manual Let me know if this service manual is close enough to your model number. At this point I am looking for air blockage behind the rear panel of freezer. If air is being blocked by ice and frost you can use a hair drier to help speed you up while melting ice. If drain is blocked use whatever you can to open the drain line mentions on the links I sent you to and let me know what is found, Thanks Sea Breeze
Feb 18, 2012 | LG LFX25971ST Bottom Freezer French Door...
Large amount of water collecting inside refrigerator
water drainage passage and pipe is blocked stop the refrigerator and clean the pipe
Sep 08, 2009 | Whirlpool Refrigerators
Ice forming in the bottom of the freezer
Unclogh the drain hole inside the freezer in the bottom of the bakc wall pouring hot water until the ice melted and keep pouring until goes through.Repet this every 3 or 4 months to keep it clear.
Jul 22, 2009 | GE GSL25JFPBS Side by Side Refrigerator
LARGE AMOUNTS OF ICE FORMED IN THE MAIN COMPARTMENT
Well, short term, you'll have to unoad it and defrost manually.
Sounds like the auto-defrosting system has a problem. A likely cause is the defrost timer.
May 04, 2009 | Refrigerators
Ge refrigerator makes ice but does not dispense ice
FROZE UP RESEVOIR BEHIND REFRIGERATOR DRAWERS. PULL OUT FRUIT AND SNACK DRAWERS AND DEFROST WITH BOILING WATER OR A HAIR DRYER.
Nov 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
460 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
