Question about Refrigerators
Kenmore Refigerator 21 cub Top Freezer not able to freeze water
Bought in 1999 model # 106.78187891
The refrigerator part may not be getting as cold as it should be and
there is a vibrating fan noise in the freezer
    Problem Solver:
  • 19 Answers
There are number of things that can cause this problem, 1).Check your defrost cycle, your refrigerator might have ice build up due the timer not going into defrost, or 2). your Defost heaters are open, 3) the Evaporator motor is starting to wear out, it might have a bent shaft due to it chaffing onto the ice build up. The fan the vibration is properly ice now chaffing onto the fan blades.
Posted on Feb 21, 2009
  • 150 Answers
Sounds like you are about ready to loose your circulation fan.It is located in the freezers back wall.You should replace it.Not to difficult.If you need a walk threw let me know.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Unit was making noise. bottom freezing, top meling, no cold air blowing into the refigerator from freezer
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Amana Refrigerators
Kenmore 18 top freezer doesnt freeze completely. refigerator cools to 48 f .
possible causes: bad door seals or condensate drain plugged causing evaporator coils (in freezer) to ice up, condenser or evaporator fans not on, condenser coils dirty, compressor not working, or a freon leak. if the back wall of your freezer is frosty or super cold, the coils are iced up. remove the back wall and defrost it with a hair dryer. if the water doesn't drain, unclog the drain tube. check the door seals for gaps. replace if necessary. check the fan in the freezer and the fan in the back. both should come on when the compressor is on. if not, check the fuses on the main board. replace if needed. if all that is fine, and there is no frost, you have a slow leak or a bad compressor. call in a pro or get a new fridge.
Nov 12, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Hot to touch
there is another fan at the bottom, rear, of the refigerator. remove the bootom panel and look at the cooling fins to make sure they are not bent into the fan blades. Caefully bend the fins away from the fan. this should improve the cooling of the refrigerator and get rid of the hot spot on the rail between the refrigerator and freezer.
Apr 26, 2009 | Kenmore 53542 / 53544 Side by Side...
Freezer is not freezing properly and the refigerator is not cold
You have a defrost problem. The fridge gets cold air from freezer, if ice blocking from no defrost, no fridge temperature.
Apr 26, 2009 | Kenmore Refrigerators
Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Oct 26, 2008 | Kenmore 53642 / 53644 Side by Side...
Freezer staying cold but defrosting on Kenmore Refrigerator dripping into bottom frig
I bought kenmore refigerator 21 cu.ft. year ago, but recently on top of freeze door side produces ice would you please tell me what's happen and how to prevent.
Sincerely,
Tim Kao
Jul 09, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore refrigerator not cooling
Is there frost on the back wall? If so your coil is frozen up and you have a defrost problem. The water coming out of the freezer door could also be caused by the same problem.
May 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
130 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
