Back to:
Tags:
Toshiba W603 VCR
Problem loading tape on 4yo Toshiba w603
By Brad - usenet poster
I used to think toshiba was an 'ok' brand, until I got this VCR a few years
ago. General complaints aside, it worked ok up until now. Now the unit has a
problem when I put a new tape, and/or turn the power on when a tape is
present. The clock/display flashes on and off for a couple of minutes, or
longer, before eventually working, but it's getting worse. Looked in the
manual and there's nothing about this. It seems like the motor unit or
something is going - not getting power or something. Time for a new one, but
is it worth looking into to repair myself or get someone else to look at it?
Thanks, Tony
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Charlie
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Seems to be a power problem, since now the front time display won't light
up, and the 'helper' motor inside just goes back and forth in little ticks.
It appears to be toast. Luckily the last tape I got out of it was an
important one, and the one I put back in for testing was a junker (haven't
gotten that one out).
-Tony
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on problem loading tape on 4yo Toshiba w603:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Green1
Rating: 0%, 0 votes
change all caps in psu for a start,.
b.
Thank You!
Can you Help with these VCRs problems?
VCRs
I have connect my SD-V394 Toshiba DVD/VCR combo to my Sony...
VCRs
Does anyone have the new codes for the ntl box in ireland?...
VCRs
before going on direct tv i was able to record programs on...
Toshiba W603 VCR
I can't access the menu to figure out how to take the on...
Toshiba W603 VCR
No way to access Menu to set timed programs, clock will...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
