Question about Hitachi (HTS424040M9AT00) 40 GB Hard Drive
COMPAQ PRESARIO V2000 BOOT PROBLEM
My 2005 Vintage Compaq V 2000 laptop is not booting after working fine with proper shut down , from and while I go to the CMOS Set up and check the Hard Drive I Get NO IDE DRIVES DETECTED I replaced the Hard Drive with a New Hard Drive of Seagate 100 GB still the same message no IDE Drives detected .
Please help
  • 27 Answers
As much as I would like to tell people do not buy seagate I can't, Most Seagates are having problems, depending on the serial number you might need the firm ware up date. Secret WD is the way to go, better warranty, last longer to.
Posted on Sep 03, 2010
Compaq Presario v2000 freezes
If your laptop freezes randomly follow the steps given below:
  • Disable Unnecessary Services
  • Run Disk Checkup
  • Disable Startup Programs
  • Clean Registry Errors
You can also get more help from this article:
http://www.backspacetab.com/laptop-freezes-randomly-tips-to-fix-this-problem-for-good/
Dec 08, 2011 | HP Compaq Presario V2000 Notebook
My Video Controller(VGA Compatible) does not respond My laptop is Compaq Presario V2000 Win XP
-do you have any display at all?
--if yes
can you try to boot to safemode with VGA Mode?
-press F8 when booting up, then it will give you the boot option, select boot to VGA mode, then roll back the friver or re install it
-if you don't have a video at all, try to remove the LCD cable and plug it back in ( you have to open the laptop's chasis
Sep 04, 2010 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 laptop wont boot
hi it seems that ur mother board has been damaged.. and immediately u should go for replacement....
thank u!!!
Apr 09, 2009 | HP Compaq Presario V2000 Notebook
Won't boot up, Hard drive self test result #1-07 Fail
Hi there.
The hard drive has failed and you will need to replace it.
If the laptop is under a year old take advantage of the warranty and send it in to be repaired for free.
Good luck and thanks for using FixYa!!
Apr 06, 2009 | HP Compaq Presario V2000 Notebook
My HP Compaq Presario v2000 has new mobo, new CPU
You probably put more than a pin-head size drop of heat grease compound on CPU, thus "bleeding" over on the CPU, effectively overheating processor (very common). In any event, your problem is overheating -that's *the* place to look for now.
gurutim
Mar 18, 2009 | HP Compaq Presario V2000 Notebook
Freeze after boot up
hmm... given that it boots up fine into safe mode, i think there's a strong possibility that the problem is virus or spyware related.
i would see if you can run a virus scan with some good programs, check your startup processes to see if you find anything out of the ordinary, etc.
if you do find something or also think its a virus, reloading windows will always take care of that, and definitely speed up your system.
hope this helps
Jan 03, 2009 | HP Compaq Presario V2000 Notebook
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
Doesnt boot to windows
Normally this means there is a problem with either the memory or the board. You might have to do more isolation such as trying the memory on another computer etc.
Jul 27, 2008 | HP Compaq Presario V2000 Notebook
Compaq presario v2000 notebook will not boot up blank sreen
If it is working fine with AC Adaptor, change your battery it need replacement.
Feb 09, 2008 | Toshiba Satellite A15-S129 Notebook
Hitachi (HTS424040M9AT00) 40 GB Hard Drive Logo
186 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
