Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Service light is on say's to reffer to manual
Heater is working on spa mode yet water is not getting hot at spa, green light on heater is blinking and service light is on at AquaPure Servuce Panel:
  • 125 Answers
My Balboa 300F hot tub will not heat up. I am not able to get it out of economy mode. What can I do?
First, balboa does not manufacture hot tubs! They make control systems for hot tubs. If you are no longer able to switch between modes, then your topside control panel buttons are dead or falling. But... Even if you are still in economy mode, spa should still heat up. Once a demand for heat is recognized, you have a "Heat Call" and heater should come on. Is the "heat on" light, illuminated? If so, water should be heating, if not heater element may be bad? A multi meter would be good here: is there proper voltage at terminals on circuit board to heater? If so, bad element! If no voltage, then heater is not necessarily bad, probably just fine, I would then look at sensors? Good luck
Feb 23, 2015 | Pool & Spa
Service mode Compool
turn everything off then turn back on if it is still uncontrolable sounds like master pc board
Feb 27, 2014 | Pentair Compool CP3400TX Pool & Spa...
No heat from heater
Copy following link to help identify water heater.
http://waterheatertimer.org/How-to-fix-water-heater.html
Add a comment and describe water heater in detail. Attach video with clear description.
If unit has blinking lights, then check product manual for error codes from blinking lights.
If unit is delivering no hot water, check for cross connections
http://waterheatertimer.org/Crossover.html
Call service technician and catch up on routine maintenance, such as cleaning water filter, etc
Jun 10, 2013 | American Heat ADK-2 - Electric 8.2KW...
Rheem rte13 standby (green) light not on
You might have crossover problem caused by bad faucet cartridge.
The green standby light should come on when 240Volt power is applied. Page 6 manual.
Both red lights should come on when tankless is activated. Page 6 manual
RTE 13 requires 60 amp breaker and 6 gauge wire
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
http://waterheatertimer.org/pdf/Rheem-TanklessElectricUC_AP15447.pdf
Factory temperature setting is usually default 120 degrees.
Adjust temps page 11 manual
Thermostat calibration is always approximate.
120 degrees is not hot enough to burn the skin.
Exceptionally cold incoming water temperature can cause tankless not to heat enough hot water: install tempering tank to preheat water to room temperature.
Tankless cannot be exposed to more than 11 grains hardness in water. Delime tankless yearly, clean water filter monthly, do not install low-flow restrictions or conserve water since the flow rate must remain high for tankless to activate.
Rheem does not post service manuals for their tankless water heaters.
Call Rheem 800 432-8373
Aug 05, 2012 | Rheem Tankless Hot Water Heater...
Is there a reset button for a 6G50NVH-FV-02 hot water heater
Depends on gas control valve, and if cause is overheating high-limit event or FVIR flammable vapor event.
Turn off water heater when using flammable vapors, clean burner parts to prevent overheating.
1) GSW Residential power vent gas water heater with FVIR system:
Some models have intelli-vent gas contol
Others have robershaw gas control with auto-reset
2) Parts manual shows #15 'auto-reset' high limit switch on the blower
http://www.gswpartsonline.com/model/27484
http://www.gswpartsonline.com/schematic/137/view
3) Possible manual:
http://www.gsw-wh.com/pdfs/GPD135NInstall.pdf
Shows resettable lockout page 15
Water temperature must be 120 degree F or lower for reset. Unplug power cord, and then plug back in and wait 15 minutes or 60 minutes depending on gas control valve.
Some intelli-vent controls must be replaced when 195 degree high limit event locks out the water heater.
If high-limit lockout repeats, then gas control must be replaced.
Also clean burner parts, air intake, and make sure flame is clear blue. and not yellow-or-orange.
4) Intelli-vent service manual might apply to your water heater:
http://waterheatertimer.org/pdf/Intellivent-service-manual.pdf
If FVIR flammable vapor event locked out heater, then unplug heater and plug back in.
Immediately press two temperature buttons. Wait for green light to blink. Release buttons.
Page 34 in troubleshoot chart.
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 31, 2011 | Fasco GSW Hot Water Heater Exhaust Draft...
I have a honeywell pilotless hot water heater control model wv4460e. This unit is not working and I was trying to trouble shoot it. I have tried to unplug it and plug it back in and it seems like the...
The blinking light is actually an error code. See the trouble shoot section in the manual: http://www.bradfordwhite.com/images/shared/pdfs/manuals/45960A.pdf
Jan 28, 2011 | Kitchen Ranges
Tub is not heating to temperature and flashing a Ec message on the temperature screen.
the Ec message is reffering to the mode the tub is set for. Ec stands for Economy mode. In Economy mode the heater will only come on during the filter cycle you have programmed. It will take a while for the tub to actually heat up in this mode. Change the mode to St mode which stands for Standard mode. Your manual should explain how to do this. usually you hit the temp button then the light button to change from mode to mode. Once the St is in the read out window don't touch anything and it will except the programmmed entry automatically. In the Standard mode the tub will keep heating until the set temperature is reached. then it will come on every half hr or so to check that the temperature is maintained.
Oct 09, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Pool heater is not working properly
So I assume you have pressed the button by pool to select the pool thermostat? If this doesn't work sounds like another mother board problem, or try powering down the unit a few minutes then restart. IF you haven't pressed the pool button, the read this: The heater comes factory set at 78° F. for the pool mode and 100° F. for the spa mode. If it's in spa mode it's trying to get to 100F. Using the up and down arrows,you can set the thermostats to a minimum temperature of 65° F., or a maximum of 104° F. If you desire to heat only one
body of water, the thermostat is capable of an off mode. As an example, if you only wish to heat the pool and not the spa simply depress and hold the spa down arrow, and the thermostat will lower its setting to 65° F. then go to an off mode. Here is a link to your manual :http://www.pentairpool.com/pdfs/MasterTempOM.pdf
Jul 07, 2010 | Pentair 460732 MasterTemp Heater 250BTU ...
Jandy pool heater model #LT400N-L service and ES1 light blinking
The heater won't fire up if there is no or inadequate water flow. Ck water pump and filters.
Jun 01, 2009 | Jandy Lite2 LG400 Ceramic Compact Heater
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
461 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
