TV keeps going up in channels on It's own even when I turn it off (standby) it turns itself back on and does the same thing. I have no idea how to fix it. It just randomly happened last night while I was watching TV
SOURCE: samsung tv LE32R74BD standby light on but wont turn on
samsung tv le32r74bd had tv on standby and wont turn on,it is stuck on standby please can you solve this
SOURCE: remote not working!
Hi, I have just had same problem and rang Samsung who sorted it ! All that was required was to reset remote by taking out the batteries then press power for approx 10 seconds and then replace the batteries and hey presto it worked!
SOURCE: 42" Samsung plasma keeps turning off
I have over 10 years experience in electronic tech support.
I
know this isn't what you want to hear, but the problem you've described
can't be fixed with troubleshooting. Your TV will have to be repaired.
There is a part that has developed a defect and needs to be replaced. If
you're still in warranty, the TV will be repaired at no charge to you.
The warranty would likely be at least one year from the date of
purchase from the manufacturer. If you purchased an extended service
plan they will repair the TV at no charge as well.
If
the TV is no longer in warranty, it will likely cost a minimum of $150
parts and labor. This is assuming that you only need a power supply
module. If the problem is more than one of the circuit boards, the price of
repair could go much higher.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from here.
Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
SOURCE: Samsung LCD 40 inch LNT4061
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thanks for using FIXYA, big IRISH.
SOURCE: Sometimes Loses Sound
disconnect the hdmi cable from both ends it resets the sound signal!!!
