Question about Amana ARB9059CS Bottom Freezer Refrigerator
Just want to know the location of the defrost timer
Mod. number ARB9059CS
    President:
  • Amana Master
  • 2,651 Answers
The defrost timer is located within the upper light assy iin the refrig section, not an easy one to find but it in there
Posted on Feb 21, 2009
Location of defrost timer on mod 59292991
I think you are missing the first three numbers
Sears numbers look like this 123.456789
Appliance 911 Sea Breeze
Aug 26, 2015 | Refrigerators
Where is defrost timer location on fridgedaire mod # ED25DQXVN00
Your mechanical defrost clock timer is located in the control panel where the rotary knobs are for the ED25 model given which is a Whirlpool SxS, For the Frigidaire Mod FRS, your defrost control will most likely be located in the long housing running down the center wall (front to back) of the fridge near the outlet vent, this is an electronic adaptive defrost control. Pleazer Appliance...
Apr 18, 2014 | Frigidaire FRS26KR4A Side by Side...
I can't find the wiring diagram for my whirlpool refridgerator.... MOD.#ET19RKXFN01 SER.#EG3222178. Can you please help. I need to change the defrost timer.....Thanks
I will try to locate a wiring diagram for your model ET19RKXFN01 but to change the defrost timer you will only need to know its location. Here is a link to the repair parts=> ET19RKXFN01_Repair_Parts_List
Go to page 5 of the repair parts list and you will see item number 4 Then on page 6 of the parts list you will see the timer part number beside the item 4. That is your defrost timer part number 2193084 Defrost Timer
Your refrigerator is an older model and may have the wiring digram in a packet behind the kick plate in the front near floor. Changing the defrost timer will not require use of a wiring diagram. Simply remove the old timer and replace the new defrost timer by plugging it into the wiring harness. The defrost timer can be found behind the control panel inside the fresh food compartment where the controls are located above the top shelf. If you have questions just let me know, Thanks Sea Breeze
Nov 30, 2012 | Whirlpool Refrigerators
Fridge stopped cooling but freezer works what could it be
Most likely the=> WR09X10041 Defrost Timer
found inside the fresh food section and behind the control panel. Click HERE for the location. Part location number 648 is the defrost timer. Location number 618 is the=> WR51X10038 Defrost Heater Assembly
If you change the defrost heater then you should also change the WR50X10071 Defrost Thermostat
and that is the location number 620 found HERE First I want you to try turning the defrost timer slowly clockwise until compressor and fans stop. Leave like this up to about 30 minutes. You should hear crackling and sizzle noise inside the freezer. If after 30 minutes the compressor and fans do not restart this will indicate the defrost timer and that part will need replaced. Try that first and let me know what happens. I will be here to answer questions if you like, Thanks Sea Breeze
Aug 15, 2012 | GE Refrigerators
Hi im tring to locate the defrost timer in my samsung fridge can you help?
Go to here for diagram:
Have your mod number ready
http://www.searspartsdirect.com/partsdirect/index.action
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 06, 2010 | Samsung Refrigerators
Whirlpool Mod ET18LKXHWo o Fridge not freezing,
Your defrost timer located inside the control panel is bad OR the defrost thermostat located on a freezer coil is bad.
Get down low and look up at the bottom of the control panel.
You will see a small round hole. Onside the hole is the defrost timer advance knob.
Use a flat blade screwdriver and SLOWLY turh the slotted knod clockwise until the refrigerator clicks off.
Wait a few minutes then open the freezer door and listen for a sizzling sound from the freezer compartment.
If you do hear a sizzling sound that would be the defrost heater melting ice.
If you do not hear a sizzling sound,unplug the refrigerator and remove the rear freezer panel to expose the cooling coil.
Clipped to the coil will be the defrost thermostat. It will need replacing.
If you do hear the sizzling sound the defrost timer will need replacing.
Jul 20, 2010 | Whirlpool Refrigerators
Fride not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 04, 2009 | Amana ARB9059CS Bottom Freezer...
Freezer freeze up
Your model TFX20JRBKWWW uses a defrost timer part number WR9X489 located behind the light shield in the fresh foods compartment. (top back area). Just in case you need to know, the defrost heater is a part number WR51X10101 located behind the back wall of the freezer.
Dec 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana ref mod.drb2201cw I need to replace the defrost timer wher is it located
you left the chat but if you want to see a view of it go to www.apdepot.com enter the make and your model number and you can see the timer there
Sep 10, 2008 | Refrigerators
GE Frig mod#TFX26KPDA
More likely, the defrost system has failed.
There are three components: Defrost timer, a defrost heater, and a defrost bi-metal.
The timer can be located either in the food compartment, on the rear of the unit, or behind the kickplate. The heater and bi-metal are located behind the freezer rear wall (or freezer floor, depending on design). It's easiest to unplug the fridge overnight, with the freezer door open, to melt all the ice that has developed. PRIOR to doing all this, please ensure that there IS ice forming on the wall of floor of the freezer! Let me know. I hope this helps!
Jul 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana ARB9059CS Bottom Freezer Refrigerator Logo
340 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
